| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#451 |
Up to you. I spent less then $100, and kept the DEXA to the DAC where it made the most sense. Check with Morgan Jones' book on what components are good and bad and why. This research is backed up other places as well. It will also supply proven mathematical formulas for changing out components. You should also use an oscilloscope and current meter to make sure you changes are making improvements. Improvements without measurements are hard to recommend. Understandable that not everything can be measured but power can, unlike cables that have to be heard.
#452 |
Super reg on DAC makes the most sense, I agree. Changes such as decoupling caps in DAC circuits are somewhat scientific too, easy to see with digital oscilloscope. However, analog stage coupling and power decoupling caps are more ear/taste matter.
78xx, 79xx regs have datasheets too... Most of the "improvements" in the analog domain are subjective, throwing money on more expensive opamps or "fairy-wings-in-virgin-blood" gold caps might make you feel good...Discerning ear is the ultimate judge. Dacmagic in stock form is quite excellent given its price/quality ratio. I would add no more than $50 worth of quality parts. On a separate note I would like to share my dealings with L1 induction coil - it was too noisy and the chirping was really loud with Dacmagic cover off. Short version: removed it from the board, cut around the base to remove ferrite shield, put some shrink tubing on the coil, packed the housing with epoxy, put it back together. Now it's silent as a church mouse... Last edited by ClefChef; 27th June 2012 at 04:25 AM. |
#453 |
And here's the list of my mods:
DAC Section: C419 - Panasonic FC 1000uf 16v C275, C303 Oscon 10uf 25v The rest are bi-polar Nichicon Muse Waiting for dexa reg. All digital section caps changed to Oscons Removed C17 and C18 from digital inputs 1 and 2 (we absolutely don't need capacitance there) bypassed C126 and C127 Analog output: removed C269 and C264, those are HF filtering caps - snip snip. opamp supply rail caps bypassed with small wimas The rest is usual cap upgrade to quality Nichicons, Panasonics, and Elnas. I have a pair of ASC LL/88 transformers, might experiment with output stage a bit since they do fit on the pcb with coupling caps removed... |
#454 |
OP275G datasheet shows recommended 0.1uf + 10uf decoupling caps on both power pins, I assume similar recommendations for the rest of opamps. Dacmagic has only 10uf per rail feeding all 6 opamps, not enough I suspect. I would recommend at least 47-100uf for C414 C415, since it would be difficult to put decoupling caps for each opamp separately.
#455 | |
Experimenting with AD797 I infer it runs stable on the XLR topology however due to current draw of 10-12mA per Opamp across 30Vdc I installed them only on the XLR+ stage, they run hot around 65-70C. The sound is the best I've heard across a range of opamps however I am skeptic to go full way on XLR stage with 8 x AD797 on browndogs |
#456 |
Today I tried running ASC LL/88 transformers on Dacmagic output. LL/88 is BBC transformer 1:1 600ohm primary and secondary, with primary centertapped. I believe they were used to convert unbalanced signals to balanced and vice versa, and believed to be made by Sowter.
Primary was connected to to balanced signal running from U55-U56 and U59-U60 and output was fed to right side of the rca coupling cap (removed). The primary centertap is left unused, although I think it could be grounded... The sound is GORGEOUS. I think I am going to remove all coupling caps and disable XLR outputs - a pair of RCA will suffice for now. I had previously removed summing opamps that feed RCA outputs and ran one-sided XLR - hardly an optimum setup. The most important thing - those trafos fit within the box and could be mounted on the pcb.
#457 |
#458 |
this sounds quite promising...
Mihaylov also mentioned this here, but it was overshadowed by the OpAmp discussions Opening the new DacMagic???? Could you share a schematic on how the xformers are connected in ? |
#459 | |
As we all know in audio Less is More. WM Dac chips already have Vout with filtering that are sufficient do drive the output, all the other opamps add distortion and coloring. I really like tube output stages, and in this case something like Broskie CF would probably work well. Smallish Dacmagic box makes me explore other options and my current transformer mod seems to be OK. Last edited by ClefChef; 3rd July 2012 at 06:09 PM. |
#460 | |
Led by your mod I found this while looking for xformer parts: Phono Preamplifier with Line Output Transformers Is the sound improvement because the xformer does the summing up of the XLR+ and XLR- signals ? When you say sound improvement in what way ? |
| Dacmagic Mods | Blue_Max | Digital Line Level | 50 | 9th March 2009 09:15 AM |
| Sony CD-X33ES CD Tray not opening-help? | eldarvanyar | Digital Source | 7 | 14th January 2008 05:12 PM |
| Help! Cracks opening in my veneer | suzyj | Multi-Way | 7 | 28th December 2006 04:42 AM |
| Cambridge Dacmagic 1 | ManUtd | Digital Source | 1 | 6th October 2003 10:17 AM |
