| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#411 |
The AD797 runs hot on U55/U56, U58/59 position however the highs are very detailed, and music sounds much better than other opamps tried, especially complex passages in classical & rock recordings.
Also running a freq sweep from 10Hz-20Khz didn't point any oscillations when measured with my oscilloscope. I recall LM49720 was also hot but cannot recall a "burned finger". Should I infer the AD797 is stable on this circuit topology besides running hot ? Re: bypassing, although datasheet recommends bypassing with 0.1uf + 4.7uf, would there be an issue with only the 47nf ECHU bypass cap already in place ? Last edited by gvelim; 5th February 2012 at 05:38 PM. |
#412 | |
regards |
#413 | |
regards |
#414 |
9V AC adaptor doesn't work for me as it causes voltage drop which in turn makes my SRegs not function properly. I have ordered some clip-on TO220 heat sinks to try out. Also I'll get the bypaasing fixed as per datasheet + the feedback cap at pin 7 + 6
#415 |
UNREG2 is the output of R107.
Feeding from R5's output is a much cleaner option with less noise as long as the voltage is good for your purpose. I am feeding from R5 the DACs' SRegulator so that way I avoid overloading the analog +SReg (7815) and improving a bit on heat dissipation. |
#416 |
[QUOTE=gvelim;2895410]UNREG2 is the output of R107.
Feeding from R5's output is a much cleaner option with less noise as long as the voltage is good for your purpose. I am feeding from R5 the DACs' SRegulator Nice idea, I will try it. About AD 797 : Check their power absorption across R400, if any oscillation is suspected. Like a guide line, sum the quiescent current ( from data sheet ) and see what you have with no signal ( 50% more or less should be ok ), then try with signal to see if you get an increased value across R400. ciao. |
#417 | |
cheers |
#418 | |
17mA translates to 0.5W which calculates as 86C on the packaging, which resembles reality. The datasheet reads -40 to 80C as normal operating temperature, so what should I infer ? Since the browndog adaptors are being toasted from both sides, I have put a clip-on heat sink per channel for regulating the temperature. Otherwise music is sweet, full in midrange and better than before, even when the LM49720s were on. Last edited by gvelim; 17th February 2012 at 10:35 PM. |
#419 |
AD797 is a bad beast, looks like yours are oscillating.....
IC adaptors are very bad for stability with hight speed op-amps, no heat transfer to large cooper lines too... The safe option is to put LM49720s back. In my opinion a couple of silmic II ( 100uf/25v ), at the output of Yours regulators, will give You sweeter HF, creamy mids and strong sub bass, like I have in my dacmagic. ciao |
#420 |
I agree browndogs could be the reason for the oscillation so I am planning to fix 2 x 1206 film caps (0.1uf + 0.47uf) per rail on the adaptor to see whether this fixes the problem.
re: Silmic II, I already have super regs installed so would they still make any difference ? also where do you buy them from ? |
| Dacmagic Mods | Blue_Max | Digital Line Level | 50 | 9th March 2009 09:15 AM |
| Sony CD-X33ES CD Tray not opening-help? | eldarvanyar | Digital Source | 7 | 14th January 2008 05:12 PM |
| Help! Cracks opening in my veneer | suzyj | Multi-Way | 7 | 28th December 2006 04:42 AM |
| Cambridge Dacmagic 1 | ManUtd | Digital Source | 1 | 6th October 2003 10:17 AM |
| Page generated in 0.12078 seconds (79.49% PHP - 20.51% MySQL) with 11 queries |
