Opening the new DacMagic????
Old 10th December 2011, 02:19 PM   #371
Tordenguden is offline Tordenguden  Denmark
Banned
Originally Posted by gvelim View Post
The more I study the digital supply the more I infer the effect of noise to clock jitter is significant hence by removing the digital noise you improve jitter performance... I presume ripple/noise affects raise/fall times hence adding to jitter.
If this is valid, in the context of DacMagic is best to tackle jitter performance by using an Ultra low noise Clock PSU + ultra low phase noise Clock + ultra low noise HEX inverter (clock buffer)... this change would give best possible results comparing to the "new power supply" path.
I have found the combo of Flea PSU + Crystek CCHD-957 + PO74G04A to give outstanding sound results.
Cool!
I have experience in soldering SMD, so that should be an easy trick. But it took me some time to find the PO74G04A. But it seems that I found it on a german homepage, since I need to buy inside EU, to avoid extra taxes and so on.
But that is, definitely a mod that I will do
I allready did the clock. I used this one.
NewClassD Audio Clocks
Only difference is, that mine does not have the output transformer. But then again, I got it for 1/4 of the original price
Old 10th December 2011, 05:36 PM   #372
Banned
Damn! It seems that I cant find a single local dealer for that PO74G04A here in Denmark
So now I have written to Potatosemi.com and asked them for advice.
I want a top notch Hex inverter to
Old 10th December 2011, 05:48 PM   #373
gvelim is offline gvelim  United Kingdom
bought from ebay here, and it was sent directly from US, total cost $5USD :
eBay - The UK's Online Marketplace
no need to purchase through a local dealer
Old 10th December 2011, 06:13 PM   #374
Banned
Thank you.
I just bought it. Even though I saw that this one i a PO74G14A and not PO74G04A. But they are very close to each other, so I took a chance
Old 12th December 2011, 08:39 PM   #375
Banned
Looked closer at the datasheet. And it seems that the difference lies in the following:
Propagation delay = 5,5ns http://www.fairchildsemi.com/ds/74/74VHC14.pdf
Propagation delay = 1,8ns : http://www.potatosemi.com/datasheet/PO74G14A.pdf
Propagation delay = 1,4ns http://www.potatosemi.com/datasheet/PO74G04A.pdf
gonna be exciting to hear the difference - if any
Old 13th December 2011, 10:53 AM   #376
It is also the special noise cancellation technology those hex inverters are equipped with. The clock clock quality that feeds the hexinv is also an important factor.
The theory is that limiting noise you reduce jitter.
Old 14th December 2011, 03:41 PM   #377
Banned
Oh yes. forgot about that feature. waiting patiently on the mail from ebay
Old 23rd December 2011, 02:49 AM   #378
With the clock improvements I have started noticing the sound of LME49720 so I am looking around for something more suitable and musical.
I have just looked at the AD8672 specs to replace the LME49720 that poses as a Differential multipolar bessel filter at the DAC's output - Wolfson DAC is operating in dual differential mode per channel, that is, 2 x dual opamps per DAC.
Considering the filter's goal is removal of common ground noise from the signal should this be a more suitable opamp (recommended for use in precision active filters) ? Open to suggestions.
The RCA stage is also running on LME49720 which I am looking to replace with OPA1612. Would there be any issue with AD8672 driving OPA1612 ?
Considering I have already removed the stage/signal coupling NP caps, could this upgrade introduce a DC offset in the outputs ?
PS: A-Class biasing mod has been postponed for the time being.
Old 23rd December 2011, 12:15 PM   #379
Banned
Im unsure if it is the LME4972 is such a goo choise. Or maybe its just because you now can hear the true nature of the wolfson dac. I dont know. But I was just afraid that the 1612, would be to "closed" in the sound. Because I do not want less detail than what the 5532 gives me.
Old 29th December 2011, 04:41 PM   #380
following upon earlier discussions on post-DAC stages and
1) since I am using XLR->RCA using only (R+,GND) & (L+,GND)
2) all 6 x LME49720 were getting too hot
3) had already bypassed the output coupling caps
... I decided to "disconnect" the RCA stage which was implied that increases the Diff filters' output load and subsequently influence THD distortion. Hence I removed U61/U57 and C6/C48. C293 & C299 were already removed.
I played the system with the remaining 49720s on. The sound was felt with increased detail in highs and micro-dynamics, but not a day night/difference.
Then I moved on to replace the 49720 with OPA2211. All well with the SMD job however the sound was coming out distorted on the highs. This revealed that one of the 4 opamps was baking hot. Removed and resoldered and the it was absolute fine. I played some sample tones via USB tones and I did not notice any oscillations on the output, which was quite reassuring. The opamps are running also much cooler.
The sound & stage appears to be on par to 49720 however fatter on base notes... at least it is not worse to my ears, so I'll let it burn for awhile.
A big PLUS of the opamp change is that box temperature has dropped to a point that I can keep my finger on the opamps and regulators' aluminium alloy for more than 15'' without any discomfort... comparing to 5'' before that was already a painfull experience.
Opening the new DacMagic????Hide this!Advertise here!
Dacmagic Mods Blue_Max Digital Line Level 55 27th February 2016 12:53 PM
Sony CD-X33ES CD Tray not opening-help? eldarvanyar Digital Source 7 14th January 2008 05:12 PM
Help! Cracks opening in my veneer suzyj Multi-Way 7 28th December 2006 04:42 AM
Cambridge Dacmagic 1 ManUtd Digital Source 1 6th October 2003 10:17 AM
