Opening an Ipod to get the I2S signal for a digital output
Old 11th April 2009, 04:57 AM   #1
gaetan8888 is offline gaetan8888  Canada
Default Opening an Ipod to get the I2S signal for a digital output
Hello
I want to use a mp3 player to play wav or lossless files with a digital output to feed a TDA1541A non-os Dac.
The Iriver H100, H120, H140, did have a SPDIF digital output but those models are hard to find.
So, I would find an old Ipod like the G1, G2, G3 or G4, or the Mini 1, and open it to bypass the Wolfson Dac to have the I2S signal for a digital output to feed a TDA1541A non-os Dac.
The first and second generation iPods used the- WM8721; the third generation ysed the- WM8731L. The fourth generation - WM8975 CODEC; and the fifth generation - WM8758 Audio codec.
But looking at those Wolfson Dac data sheets, I am not sure which pin of the Wolfson Dac I need to bypass to get the I2S signal ??
Any hints ?
Thank
Bye
Gaetan
Old 11th April 2009, 05:45 AM   #2
Hello
Here is the links to the Wolson Dac
http://www.wolfsonmicro.com/uploads/...731_Rev4.3.pdf
WM8971 it is same than the WM8975
http://www.wolfsonmicro.jp/uploads/d.../jp/WM8971.pdf
WM8978 it is same than the WM8758
http://www.wolfsonmicro.com/uploads/...nts/WM8978.pdf
Bye
Gaetan
Old 11th April 2009, 12:15 PM   #3
amc184 is offline amc184  New Zealand
amc184's Avatar
Most iPods use a PP5020 or PP5022 SoC by PortalPlayer (now defunct, adsorbed by nVidia). As far as I can tell they use I2S between the cotroller and the DAC, so should be OK to connect to a DIY TDA1541A DAC.
I think I2S should be taped like below:
WS: (DACLRC) WM8721(4) WM8731*(9) WM8975(7)
BCLK: (BCLK) WM8721(2) WM8731*(7) WM8975(5)
DATA: (DACDAT) WM8721(3) WM8731*(8) WM8975(6)
* 28 QFN package, which I think most iPods use.
Looks like a good project, good luck.
Anton
Old 11th April 2009, 12:23 PM   #4
amc184's Avatar
This site here shows which iPod models use which SoC and DAC. I would stick to the PP5020 and PP5022 models, the PP5002 may use AC'97 (but probably not).
Old 11th April 2009, 05:49 PM   #5
jcarr is offline jcarr  United States
Rather than an iPod, I'd recommend field-recorders like the Roland R-01, R-09, Sony PCM-D50, or (at higher cost), Sound Devices' 744T.
Both the R-01 and 744T are equipped with CF slots (the R-09 uses SD while the Sony uses MemoryCards) and the 744T also is designed for a 2.5-inch IDE HD (which can be swapped for an SSD), so you can avoid rotating media.
I have modified iPods for CF/SSD operation and they work fine, but these will require more work than the Rolands, Sony and Sound Devices to achieve solid-state operation, and extracting SPDIF or I2S output will be considerably more difficult than on the Rolands and Sound Devices.
The Rolands have Toslink, and the 744T has coax SPDIF. Getting I2S out therefore should not be that difficult, although a service manual or schematic would be useful.
Sound quality is outstanding.
hth, jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 11th April 2009, 10:55 PM   #6
EUVL is offline EUVL  Europe
Do they have built-in low jitter clocks ?
Patrick
Old 11th April 2009, 11:20 PM   #7
amc184's Avatar
I would still go for an iPod. They are much easier to find, and just because the Rolands etc. use S/P DIF doesn't mean you can access I2S directly in them (although you might be able to, I am not familiar with these devices), and a S/P DIF recovery circuit would add alot of complexity while being detrimental to performance.
I doubt iPods have low jitter clocks, just a standard grade crystal attached to an oscillator circuit onboard either the SoC or DAC. You may be able to install a low jitter clock, depending on what sort of clock layout the iPod uses.
I'd love to know what sample rates and bit depths the SoC is outputting. Unfortunately I can't find the datasheets for any of the iPod SoCs (PP5002, PP5020, PP5022), and the DACs used accept such a variety, so they don't help in narrowing it down.
Old 11th April 2009, 11:59 PM   #8
Hello
Jcarr
Those field-recorders like the Roland, Sony and Sound Devices cost too much money for me.
I would not buy a new Ipod but a used or refurbished one, or a refurbisher Sansa (easyer to find at low cost but it use another dac chip).
Amc184
Here is the only portal player chips data sheet that I found (PP5002, PP5020, PP5022) , they are short version data sheets;
http://web.tagus.ist.utl.pt/~rui.nev...108_Public.pdf
http://web.archive.org/web/200612021...108_Public.pdf
http://web.archive.org/web/200609082...rief_Mar05.pdf
Thank
Bye
Gaetan
Old 12th April 2009, 02:34 AM   #9
amc184's Avatar
Yeah, I've already seen the product briefings, but they don't even come close to having the info of a datasheet. Looks like the datasheets were distributed with an NDA, probably only to a few OEMs. I doubt they'll ever see the light of day.
Old 12th April 2009, 06:37 AM   #10
Hello
Btw, the player I will use will be stationnary and will be in a metal box on the top of my amp in my home.
Sansa player do not play wav, so no more Sansa. And Ipod do not play flac files.
But there is a very interesting player, the Rio Karma, it use a laptop hdd and it use the PP5003 and the WM8721.
And it play wav and flac files.
So I just need to find a used or refurbished Rio Karma.
About the dac;
(quote)
Rio Karma DAC
The DAC is fed with standard I2S signal. The pins are:
Pin 2 - I2S bit clock
Pin 3 - I2S data
Pin 4 - I2S left/right clock
However, there is no external 256fs master clock signal, which may be required to drive an external DAC setup. The Wolfson DAC is special in that it will accept a 272fs or 544fs master clock, which is great if you have a 12/24MHz clock kicking about (e.g., a USB clock) but not very standard for audio components. Also, the lines are not buffered and are at 3.3v levels - you may run into signal integrity problems over a cable run and the lines are not particularly protected against static discharges as they were never supposed to run outside the case.
(end quote)
But the PP5003 do seem to have a SPDIF output but I only have the short version of data sheet, so I do not know from which pins it goes out.
Here is somes web sites links about the Rio Karma;
The Portal Player chip product briefings file;
http://web.archive.org/web/200702182...108_Public.pdf
The Wolfson WM8721 dac;
http://www.wolfsonmicro.com/uploads/.../en/WM8721.pdf
Others Rio Karma web sites;
http://www.rockbox.org/twiki/bin/view/Main/RioKarmaPort
http://www.dapreview.net/p/content/c...hp?content.193
http://www.schenkzoola.com/karmaopen.htm
http://www.karmalimbo.com/
http://www.karmalimbo.com/dnna_karma_description.pdf
Thank
Bye
Gaetan
Opening an Ipod to get the I2S signal for a digital outputHide this!Advertise here!
anyone know the RMS output of an ipod? gain Digital Line Level 70 1st November 2008 07:26 AM
iPod's line level output? Dxvideo Chip Amps 9 26th May 2007 02:41 PM
splitting a digital signal bser Digital Source 4 26th October 2005 05:43 PM
Get digital signal from an old CD-Rom without digital output genome Digital Source 5 3rd February 2004 11:54 PM
Copyright ©1999-2017 diyAudio
