Go Back   Home > Forums > Source & Line > Digital Line Level
Old 6th April 2009, 06:41 PM   #1
dsavitsk's Avatar
Default Differential TDA1543 based NOS DAC
Something I have been tinkering with for a while. This is basically your everyday TDA1543 NOS DAC except I put an inverter on the data line which flips the output phase. By using one chip inverted, I ended up with a differential pair. In hindsight, an Xor splitter might work slightly better, but this does the job.
In order to drive some headphones or long cables, I used a differential mosfet pairs and transformer coupled the whole thing. Since both sides are biased up the same amount (accomplished by carefully matching the mosfets, and then adjusting Vref a tad), no DC flows across the transformer. I also breadboarded a version without the mosfets using higher impedance transformers (Lundahl LL1930's) and even used as step-up devices, it worked pretty well with short cables.
There is also an ASRC. With these chips, this only seems to work at 44.1KHz, so I am just using the recovered clock from the receiver chip into the ASRC as a bit of a jitter reducer. Trying it with and without the chip, it does seem to help.
http://www.ecpaudio.com
My TDA1543 DAC based on P. Daniel Design Algar_emi Digital Source 8 11th March 2006 02:12 AM
My tda1543 based dac (as if there where not enough of them around ;o) hifi Digital Source 18 5th October 2004 10:13 AM
Looking for an active I/V stage for TDA1543-based DAC IpsilonSound Digital Source 21 17th June 2004 08:34 PM
tube buffer for TDA1543 based dac sparkle Tubes / Valves 11 25th February 2004 08:24 PM
grounds in TDA1543 based dac sparkle Digital Source 7 15th January 2004 07:54 PM
Page generated in 0.08417 seconds (75.42% PHP - 24.58% MySQL) with 10 queries
