| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
HI
Since my CAL DELTA is sick i need a digital source for my ZERO DAC , i have a TEAC ZD5000 ,no coaxial output , the transport seem to be of very good qualite ( all metal ) does anybody knows how to get the signal out ??? it use BB pcm53jd-v and JRC 5005 output op . thank |
#2 |
Is it possible to get the digital signal from the : sub cod out connector in the back of the teac ? it doesnt have a digital out
Teac dont seem to be popular here ?????? |
#3 |
I'm interested in general strategies for getting a coax digital output from some of my thrift store finds, so I'm interested in this question as well.
John |
#4 |
Try and find some docs on the DSP chip that does the oversampling stuff. If you're lucky, it has an S/PDIF output. If not, maybe it has some signals that can feed an S/PDIF transmitter like the DIT4096.
Which reminds me... I haven't pulled the cover off my "new" Sony CDP-C215 changer (found beside a recycling dumpster) to see what's inside. |
#5 |
Thank do you know some # for that chip ...
#6 |
I found those chips Sony cx23035 ( digital filter ) and Nec 7508h ADC ???
Can i get I2s out of one of these chips ??? |
#7 |
Not sure. I can see that PCM53 has a parallel 16 bit input...
#8 | |
Neither a digital filter, nor an ADC You cannot get I2S from the cx23035 but can probably convert to it or use an SPDIF transmitter chip if you want SPDIF. Either way it's a lot of work and serious surgery. Is it worth it?
#9 |
Thank Analog your problably right , not worth the trouble
just have to get my Cal delta fix ..... |
#10 |
I pulled the covers off: the Sony CDP-C215 changer (and most likely the CDP-C211 and CDP-C315) is an excellent candidate for adding S/PDIF output. The DSP is the CXD2500, which has an S/PDIF output pin 60 "DOUT" and "high" on pin 59 "MD2" enables it. There are various unpopulated components and jumpers marked "C515 only" on the board just waiting to implement S/PDIF out via Toslink.
To get at the PC board, remove the bottom cover. Then some screws and various cables. None of the "flexible pcb" style cable connectors had locks to release. Once you've removed the PC board, the jumpers that must be added or changed are silkscreened on the board. Pin 59 (MD2) is jumpered to GND so one jumper near the DSP must be cut and another added. There's R305... your guess is as good as mine as to the proper value, but maybe 47 to 100 ohms. Caps C412 and C413 near the optical transmitter... 0.1uF ceramic? and an electrolytic bypass... 1u to 50u at 10 to 16V? Then you need the optical transmitter... it looks like the pin order matches the TOTX178A. Alternatively, add a buffer for an RCA output, like I did on my Hitachi/Pioneer laserdisc player. Schematic, layout, and pictures of the end result are here... If I'm reading the CXD2500 datasheet correctly, pin 60 is only rated at 1 mA out, so driving an S/PDIF output without a buffer looks risky. |
| How can I convert SPDIF to EFM (RF) signal, to use a cd player as a DAC ? | gaetan8888 | Digital Line Level | 10 | 8th February 2009 07:32 AM |
| Sony DVP-S9000ES Digital Signal Tap | wdavis009 | Digital Source | 0 | 31st December 2005 03:54 PM |
| splitting a digital signal | bser | Digital Source | 4 | 26th October 2005 05:43 PM |
| True Digital Signal, requirements? | longblock454 | Digital Source | 5 | 16th December 2004 04:12 AM |
| Get digital signal from an old CD-Rom without digital output | genome | Digital Source | 5 | 3rd February 2004 11:54 PM |
| Page generated in 0.10776 seconds (78.55% PHP - 21.45% MySQL) with 10 queries |
