| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#251 |
That's a good suggestion. The RESET output should be high (3.3V) under normal operation. It goes low (0V) for about 200 ms when power is first applied.
#252 |
Ok thanks guys, I'll check the voltage of the reset pin 14 against ground to see what it reads when I get home tonite.
#253 |
Hi guys,
I tooks some readings tonight with a digital source hooked up and running to the EZDAC. the PIC below shows what I got. The reset voltage was on spec. Do you think that its something upstream that's at fault ? Thanks PJN |
#254 |
#255 | |
One Seriously Addicted to Audio and Electronics
Ray |
#256 |
Hi Ray,
You were right, I rechecked pin 22 on the dac chip and got 2.25v. Those legs are really close together and I must have hit the Vcc. I took a set of readings on both the AD1896 and the CS8416 and have attached them below. PJN |
#257 |
Pin 12 of the CS8416 is supposed to be 3.3V, it's tied to Vd. Maybe a bad solder joint? Same goes for pin 10 of the ASRC, and pin 9 should be 0V (tied to GND).
Ray |
#258 |
Thanks for the input Ray, I'll double check everything tonight.
#259 |
Hi Ray,
I double checked things tonite, on the CS8416 pin 12 was 3.3v, and on the ASRC pin 9 was 0v and pin 10 was 3.3. Those damn pins are so tiny and numerous that I find it easy to get lost. I checked the clock pin 4 (Vdd) 0.77v and pin 3 (out) was 0.92v I checked U4 and U5 also, the results are in the pic. I noticed that even though I had inputs and voltages on pin 6 (Vr/Vl) I had no reading on either. I used the LME49710MA which was the alt on the BOM. I checked the legs carefully for shorts and bad solder joints but all looked good. Do you think I got a couple of bad chips ? PJN |
#260 |
The readings on U4 and U5 are o.k. The opamp only amplifies the difference between it's inputs, so it's normal that you don't have any output on pin 6, since both 2 and 3 read the same.
But the clock voltages are not o.k. Pin 4 Vdd should read 3.3V and this may be the error that is keeping your ezDAC from singing! Without supply voltage, the oscillator won't do anything and there's no clock for the DAC. There's an SMD ferrite bead on the back of the board (F2) that transports Vdd to the oscillator, maybe it has a bad connection? Regards, Ray |
| F3 Builders Thread | Melon Head | Pass Labs | 454 | Today 02:13 PM |
| EZDAC is singing now!!! | ezkcdude | Digital Source | 217 | 11th December 2011 06:45 PM |
| A-X IP Issues (split from Builders thread) | tomchaoda | Pass Labs | 107 | 16th October 2011 02:05 AM |
| ezDAC chipsets | xaudiox | Group Buys | 0 | 27th May 2009 06:45 PM |
| Page generated in 0.13110 seconds (82.67% PHP - 17.33% MySQL) with 11 queries |
