ezDAC v.1.5 Builders Thread - Page 21 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 13th February 2010, 03:46 PM   #201
paulb is offline paulb  Canada
Nice. Did you find that heatsinks on the regulators were necessary?
Old 13th February 2010, 06:37 PM   #202
Yes for 3.3V Reg and +15V on the PS. The others are not really neccesary.
After listening a time I found out there is a distortion im mid/high. Does anybody has an idea what this could come from ?
I think I need to check with a scope next days..
regards Michael
Old 13th February 2010, 06:50 PM   #203
regards Michael
Do you mean it got worse, which would indicate an electrical problem, or do you think it is intrinsic to the sound? I've never really noticed any particularly harsh characteristics. Maybe my ears are not sensitive enough.
He's not hi-fi, he's my stereo.
ShinyMetal
Old 13th February 2010, 07:02 PM   #204
No it's not "harsh", sounds like an "overdriven amp". But a sinussweep is absolute clear. hmmm ??
Old 13th February 2010, 08:08 PM   #205
Evan you're absolutelty right, its is an electrical prob.
I changed the Preamp and now it's sounding wonderful.
Thanks for help. Only wondering why there is a problem with SAC Epsilon.
?? Output / Input Impedance
regards Michael
Old 13th February 2010, 09:32 PM   #206
Glad to hear it...or maybe you're glad to hear it.
ShinyMetal
Old 13th February 2010, 10:11 PM   #207
Yes for 3.3V Reg and +15V on the PS. The others are not really neccesary....
Yes, I think it would be good to use a separate lower voltage transformer for the digital supplies.
Old 14th February 2010, 02:05 PM   #208
Today I checked again and found the damned mistake.
The output resistors I put in had 24K9 instead of 24R9, so everything is
clear about that overdriven amp.
Now my ezdac is really working and sounding great !
Evan I hope now you understand my yesterdays post.
regards Michael
Old 16th February 2010, 12:05 AM   #209
PJN is offline PJN  United States
Update on progress,
I have installed most of the smd's except for a few around U1 and C15, I'll put them in after U1 is in, I'm waiting on the rest of the parts to arrive. Those tiny caps were a real pita, they were worse than the IC's. I do have a couple of questions.
On the btm right below C20' I'm guessing that is where U6 with the three legs goes, am I correct ?
Has anyone installed another clock for U7 other than the one's in the BOM ? Is there any available that could fit on the board that would make a difference ?
Old 16th February 2010, 02:23 AM   #210
You need good magnification, small tweezers, thin solder, and a thin iron to do them. I apply solder onto one pad, then slide in the SMD part from the other side as I'm re-heating the pad. Then solder the other side, and come back to the first side and re-flow, applying more solder if necessary. Sometimes you need to push down gently on the part while re-flowing one side or the other, to make sure the part is flat on the PCB.
F3 Builders Thread Melon Head Pass Labs 523 31st May 2014 03:05 PM
EZDAC is singing now!!! ezkcdude Digital Source 217 11th December 2011 06:45 PM
A-X IP Issues (split from Builders thread) tomchaoda Pass Labs 107 16th October 2011 02:05 AM
ezDAC chipsets xaudiox Group Buys 0 27th May 2009 06:45 PM
Copyright 1999-2017 diyAudio
