Go Back   Home > Forums > Source & Line > Digital Line Level
Old 4th February 2010, 07:11 PM   #191
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
I see, both BOM's list values that won't give you 12V or 15V... confusing
Now you know how they work, and able to calculate the correct values for no more troubles in the future
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 4th February 2010, 07:25 PM   #192
PJN is offline PJN  United States
Yea it is confusing especially if you don't know what you're doing like me. I'm glad I have your BOM for the EZDAC.
Old 5th February 2010, 03:56 AM   #193
If you're using the LM317/37, make sure to read the datasheet. The formula for calculating voltage is very simple (assuming the adjust current is negligible). I always assume people don't take my BOM values on blind faith, but I suppose that has not been the case.
He's not hi-fi, he's my stereo.
ShinyMetal
Old 7th February 2010, 06:09 PM   #194
paulb is offline paulb  Canada
I did run across this as a USB-SPDIF kit:
The γ1 Modular Miniature DAC configuration C, USB-SPDIF
I want a relay to switch between USB and SPDIF and am looking at if it's feasible with this kit.
Their headphone amps look good too.
Old 9th February 2010, 01:59 AM   #195
Hi All,
After watching a primer on SMD soldering on U tube I finally got the courage up to try any start populating the DAC board. It wasn't so bad after all. I do have a question on the orientation of U 4 and U5. In the picture that I've seen folks used the AD8610, but I used the LME4971 since digikey was out of the AD8610. In the attached pic I have U2 and U3 attached, but U5 is just sitting there. Is the LME4971 in the proper orientation to solder in ?
Thanks,
PJN
Old 9th February 2010, 03:24 AM   #196
Looks right to me. Pin 1 (not connected) would be the lower left pin there right next to pin 2 which is under the "MA".
ShinyMetal
Old 9th February 2010, 08:39 PM   #197
Evan,
Thanks for the info, I'll try to post more info as the build progresses so others can avoid my mistakes.
PJN
Old 12th February 2010, 07:36 PM   #198
I'm happy to report that my ezdac is up and running. I'm working on it as lunchtimes permit at my workplace (where I have access to SMD rework equipment). I used an SPDIF output from my PC, with a small passive network to change from 'TTL' to the proper level, to test it.
Now it's time to turn my attention to the companion USB/SPDIF board that I mentioned in some previous posts. Hope to have a schematic sometime next week.
Old 12th February 2010, 07:43 PM   #199
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Great, that's good to hear. Hopefully I get mine up and running soon.
Old 13th February 2010, 03:12 PM   #200
A new star is born , thanks Evan.
F3 Builders Thread Melon Head Pass Labs 398 Today 11:33 PM
EZDAC is singing now!!! ezkcdude Digital Source 217 11th December 2011 07:45 PM
A-X IP Issues (split from Builders thread) tomchaoda Pass Labs 107 16th October 2011 03:05 AM
ezDAC chipsets xaudiox Group Buys 0 27th May 2009 07:45 PM
Page generated in 0.09513 seconds (68.62% PHP - 31.38% MySQL) with 11 queries
