| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#11 |
How do you calculate the gain?
#13 |
At last I found the problem. R12 the pesky little thing wasn't soldered properly. Resoldered the resistor and low and behold wonderful loud music. A great project. Thanks
Peter
#14 |
Well, that's good to hear (literally).
#15 |
What's the max output of the op amps. As configured the output is about 2V which is about the same as the output of a CD player. When connected to the CD input of an amp it produces the correct sound levels. What I would like to do is connect the output from the DAC to a stepped attenuator then to some power amps . The output from the op amps needs to be about 8V. Are they capable of this and if so,what value of resistors should I use. Or would I be better using a line amp.
#16 | |
I think it's the current you mean? Regardless, I use exactly this setup for my ezDAC: ezDAC->attenuators->Parasound amp. I have used Endler attenuators for several years now, and am very happy with the results. |
#17 |
One Seriously Addicted to Audio and Electronics
Hi Evan,
Great to see everything is going well with the ezDAC 1.5! Mine's from the first 1.5 batch, but I couldn't resist ![]() Regards, Ray |
#18 | |
What kind of attenuator is that?? Or does the amp need 8V input? You can change the 2k0 resistors in the output stage to increase the output voltage, but if it has to be 8Vrms that will not be possible, that's too much for a +/- 12V supply Ray |
#19 |
I am getting sound out of both channels on the first hookup! ezDual is putting out perfect -13.8 and +13.8 on both leads. When playing back a song through it I am getting popping every so often in each channel, any idea what could cause that? I am still troubleshooting, (slowly, I have a final this week), just want to see if anyone could direct me down a path!
#20 |
Maybe there's a faulty connection to the output stage. Have you checked the solder joints are "clean"?
| F3 Builders Thread | Melon Head | Pass Labs | 454 | Today 02:13 PM |
| EZDAC is singing now!!! | ezkcdude | Digital Source | 217 | 11th December 2011 06:45 PM |
| A-X IP Issues (split from Builders thread) | tomchaoda | Pass Labs | 107 | 16th October 2011 02:05 AM |
| ezDAC chipsets | xaudiox | Group Buys | 0 | 27th May 2009 06:45 PM |
| Page generated in 0.11298 seconds (74.70% PHP - 25.30% MySQL) with 11 queries |
