Go Back   Home > Forums > Source & Line > Digital Line Level
Old 24th January 2010, 07:38 AM   #171
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
Good news! Progress!
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 26th January 2010, 12:01 AM   #172
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Lol, not really.
I put together everything and didn't hear a thing.
I checked the ezdual again, and now it's outputting ~2v/~-15v.
I wonder if something on the ezdac (voltage) input would cause problems on my ezdual?
Old 26th January 2010, 01:58 AM   #173
paulb is offline paulb  Canada
So the ezDual is outputting that when it's connected to the ezDac but is okay when not connected? I still think you have a short somewhere, but it could be on the output side of one of the positive regulators.
You could depopulate all the (+) regulators on the ezDac and check resistance to ground on both the power input and all regulator outputs.
Old 26th January 2010, 02:25 AM   #174
My ezdual now is outputting ~ +2v/-15v without anything connected to it.
It had been working when I repaired the shorted cap. When I attached it to my ezdac I got nothing out of it, and then rechecked it again (disconnecting it from the ezdac) and got the above voltage.
I didn't keep it plugged in long ... fearing I'd blow another cap or smoke the resistors.
Old 26th January 2010, 02:37 AM   #175
OK. Start by checking the resistance of the ezdac to ground, and then the resistance of each +ve regulator output to ground. Look for a dead short.
Meanwhile, on the ezdual, you can check the voltage input and output on the +ve regulator.
When you're ready to hook them back up, a current-limited lab power supply would be handy if you have access to one. Otherwise, use (say) 100-ohm resistors in the +ve and -ve lines running from the ezdual to ezdac. And connect/disconnect it quickly. You've had your share of smoke and broken stuff on this.
Old 26th January 2010, 03:29 AM   #176
hmm, no wonder i'm getting about 2v on the output.
I've got 3vac at ac1 & ac2 (at the ezdual inputs). I've got 16vac from both taps of the transformer (disconnected from the ezdual).
Old 2nd February 2010, 06:13 PM   #177
Default USB to SPDIf for ezdac
Originally Posted by paulb View Post
I've gone back and forth on this (I2S vs SPDIF) a few times now. My last post here said I was switching to I2S, but I haven't done anything further on the PCB design yet.
For any that are interested, I'm going back to SPDIF because it's less intrusive to the ezdac and gives more flexibility for other uses.
The adapter board will have USB and SPDIF input connectors, selected by a small relay and associated control signal. I'll start a separate thread once I'm ready to solicit comments on the design.
Old 2nd February 2010, 07:52 PM   #178
PJN is offline PJN  United States
Default Question on BOM cap values
Hi All,
I'm starting to order parts for my DAC board. On the BOM posted for the 1.5 EZDAC on Evan's site C1,2,4,5,7,8,10 & 12 are shown as 10 uF, however when I go to the digitkey number shown on the BOM they are shown as 100 uF, on the digitkey site. Could anyone please let me know the right value ?
Thanks,
PJN
Old 2nd February 2010, 10:25 PM   #179
TICUL38 is offline TICUL38  Canada
Smile USB interface... yes.
Will be tracking your posts. I have placed this project on the back burner; had to commit to other issues; speakers and woodworking are other hobbies.
Louis
All those "bits" give me indigestion!
Old 2nd February 2010, 11:26 PM   #180
Originally Posted by TICUL38 View Post
Will be tracking your posts. ...
Louis
Gosh...
I'll tidy up the schematic and post it here. I haven't done much on the layout yet.
F3 Builders Thread Melon Head Pass Labs 454 Today 02:13 PM
EZDAC is singing now!!! ezkcdude Digital Source 217 11th December 2011 06:45 PM
A-X IP Issues (split from Builders thread) tomchaoda Pass Labs 107 16th October 2011 02:05 AM
ezDAC chipsets xaudiox Group Buys 0 27th May 2009 06:45 PM
Page generated in 0.10341 seconds (78.06% PHP - 21.94% MySQL) with 11 queries
