ezDAC v.1.5 Builders Thread - Page 11 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 11th December 2009, 06:12 PM   #101
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Ok, I forgot the ezdual does have fuses on the board. So I should be fine with the 100ma fuse for the other 9v regs then.
Old 11th December 2009, 11:05 PM   #102
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
It depends, if the transformer has dual 115V primaries, you may have to put them in parallel for 115V input. The manufacturer's datasheet should make this clear. It's not very common to leave one primary floating for 115V. Also, if it has dual secondaries, you can put them in parallel as well. That way you can take full benefit of the transformer's rating.
The rating of the fuse is based on the rating of the transformers that you use. Look at the total VA rating of all the transformers that you use in your DAC. Divide the sum by 115V, and this gives you the nominal current. In this case, choose the fuse rating the same, because you will not be fully loading the transformers. Because they form an inductive load, always use a slow-blo fuse.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 12th December 2009, 04:45 AM   #103
Antek - AN-0105
Here the transformer I picked up for the opamp section. It has 2 x 115v primaries.
Old 12th December 2009, 12:34 PM   #104
6h5c's Avatar
Yep, you should connect the primaries together, red to red and black to black. Same goes for the secondaries if you're going to connect only one PSU module to it.
Ray
Old 12th December 2009, 01:54 PM   #105
That's the wrong transformer.
I've picked up the Antek - AN-0115 for the opamps
and
Antek - AN-0112 for the 9v sections.
Old 12th December 2009, 02:33 PM   #106
6h5c's Avatar
Doesn't matter . This goes for all of them!
Old 13th December 2009, 06:03 PM   #107
hmm, not sure why I'm getting only +7/-7 v out of the ezdual with the 2x15v transformers i'm using. (the two inputs are tied together as well.)
I tried with the outputs in parallel and in series (connecting it to AC1 & AC2).
Any suggestions?
Old 13th December 2009, 06:32 PM   #108
6h5c's Avatar
Yes, plenty of suggestions
You have to use all three AC inputs of the ezDual to make it work. Connect the two 15V windings in series, green to blue, and connect this junction or centre tap to AC2. Connect the remaining green and blue wires to AC1 and AC3, which goes to which doesn't matter. Should work now! Primaries go in parallel.
Ray
Old 13th December 2009, 06:41 PM   #109
I've tried all 3 wires.
I'm still getting +7/-7 on the outputs.
Old 13th December 2009, 06:44 PM   #110
6h5c's Avatar
What's the voltage across C1b and C2b?
F3 Builders Thread Melon Head Pass Labs 523 31st May 2014 04:05 PM
EZDAC is singing now!!! ezkcdude Digital Source 217 11th December 2011 07:45 PM
A-X IP Issues (split from Builders thread) tomchaoda Pass Labs 107 16th October 2011 03:05 AM
ezDAC chipsets xaudiox Group Buys 0 27th May 2009 07:45 PM
Copyright 1999-2017 diyAudio
