ezDAC v.1.5 Builders Thread
Old 21st January 2013, 06:06 PM   #361
stonedowner is offline stonedowner  United Kingdom
Haven't fiddled with my EZDac for a while, but was looking at the circuit designs the other day. The way I have it configured is as designed but using a balanced transmitter board to take the output to a balanced pre amp. Seems a bit convoluted to take the balanced current output of the PCM1798, convert it to a single ended signal then convert it back to a balanced signal. Anyone think of a better way to do this? Audio Note use transformers in their kit for the I/V circuitry but they only have a single ended output from their AD1865 DAC. Is there a similar solution for the balanced output of the PCM1798?
Old 21st January 2013, 07:43 PM   #362
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
That's a bit too complex indeed, especially since the DAC already has balanced outputs.
If you leave the I/V resistors R23 and R24 in place and add another inverting opamp, you have a balanced output right there. Just ground the + input and split it by removing R26 and R27 and duplicate the circuit.
You could use a transformer with dual secondaries, and ground the center tap, then you'll have a balanced output as well.
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 22nd January 2013, 10:59 AM   #363
Something like this :-Balanced Output.pdf
Old 22nd January 2013, 01:02 PM   #364
paulb is offline paulb  Canada
No, you have positive feedback - you have + and - inputs reversed on the lower op amp.
Old 22nd January 2013, 01:30 PM   #365
oops. This then? :- Balanced Output.pdf
Old 22nd January 2013, 04:25 PM   #366
R25 & R26 would be 100R and R28 and R34 would be 2k0. I was thinking of using LME49720-HA for the op amps.
Old 14th March 2013, 04:31 PM   #367
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
What bitrate does the ezdac handle? I'm looking at getting a new usb to spif transport.
Can it do 24/96k or larger?
ezDAC v.1.5 Builders ThreadHide this!Advertise here!
F3 Builders Thread Melon Head Pass Labs 622 10th January 2018 07:10 PM
EZDAC is singing now!!! ezkcdude Digital Source 217 11th December 2011 07:45 PM
A-X IP Issues (split from Builders thread) tomchaoda Pass Labs 107 16th October 2011 03:05 AM
ezDAC chipsets xaudiox Group Buys 0 27th May 2009 07:45 PM
