ezDAC v.1.5 Builders Thread
Old 25th May 2011, 03:46 PM   #341
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
That's right, but a PNP needs to be connected to GND with the collector, and the emitter to the LED. I used a similar circuit in my ezDAC to detect the S/P-dif signal. I used pin 14 though.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 31st August 2011, 05:25 PM   #342
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
I'm interesting in adding a USB input to my ezDAC.
I've got an internal flea clock in my ezdac, so I don't think I'd need one with the usb receiver.
(I'd also prefer to supply the usb receiver with my own 5v reg, instead of using the PC's power supply).
Any recommendations?
Old 31st August 2011, 05:55 PM   #343
paulb is offline paulb  Canada
Here are a couple of choices:
miniSTREAMER | miniDSP
The γ1 Modular Miniature DAC (the USB interface board)
I actually designed my own board but never built it.
Old 19th January 2012, 05:22 PM   #344
MFF is offline MFF  Portugal
Hi Pascal,
The connection to the master clock M to the signal MCLK, MCLOK and SCK is correct? you do not you use any fun out scheme for the CLK?
I was reading the datasheet but I do not understand the connection of M - CLK to the pin 24 of CS8416
have you some results of the DAC.
thanks for the help
Old 19th January 2012, 07:56 PM   #345
Netdewt is offline Netdewt  United States
Does info/schematic for the ezDAC exist anymore? The website seems to be gone.
Old 19th January 2012, 08:00 PM   #346
I've got docs for it.
ezdual docs
ezdac docs
Shared, you may need a gmail account. Let me know if it works for you.
Old 20th January 2012, 11:58 AM   #347
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Works for me, thanks
/U.
Old 20th January 2012, 01:10 PM   #348
If anyone is interested, I have some spare ezdac parts I might be interested in selling. (I'm putting the mini wolfson dac together.)
Old 7th February 2012, 01:30 PM   #349
alexcp is offline alexcp  United States
alexcp's Avatar
Sadly, http://ezdiyaudio.com/ doesn't seem to be working anymore. I attach the schematics, the BOM and the PCB artwork from the original website. The rest of the website is currently available from the Internet Archive.
Old 9th February 2012, 07:05 PM   #350
ilrapa is offline ilrapa
ilrapa's Avatar
Hello all ...
Maybe someone can help me ..
I have realized a PCB alternative to that of Evan (thanks :-)) in order to change the output stage with an at will ..
I only have a problem ...
I hear only one channel ...
Has anyone had the same problem??
Thanks in advance..
Dac board:
Ali board:
ezDAC v.1.5 Builders ThreadHide this!Advertise here!
F3 Builders Thread Melon Head Pass Labs 587 22nd August 2017 06:07 PM
EZDAC is singing now!!! ezkcdude Digital Source 217 11th December 2011 06:45 PM
A-X IP Issues (split from Builders thread) tomchaoda Pass Labs 107 16th October 2011 02:05 AM
ezDAC chipsets xaudiox Group Buys 0 27th May 2009 06:45 PM
Copyright ©1999-2017 diyAudio
