ezDAC v.1.5 Builders Thread
Old 15th March 2010, 12:48 AM   #241
PJN is offline PJN  United States
Hi Evan,
The V+ is coming in under the board. It was neater that way.
I took some voltages on the regulators, the pic attached shows what I measured. The layout of the sketch is the same as the layout on the board.
PJN
Old 15th March 2010, 01:06 AM   #242
ezkcdude is offline ezkcdude  United States
There's got to either be a short or open circuit somewhere on the board. Or possibly something got fried, but you probably would've realized that by now. The only way to figure out is to probe as much as you can.
He's not hi-fi, he's my stereo.
ShinyMetal
Old 15th March 2010, 07:03 PM   #243
paulb is offline paulb  Canada
It looks like you have all 4 voltages, but the designators (U8, 9,10,11) in your drawing are mixed up. At least they don't seem to match the schematic.
Old 15th March 2010, 09:23 PM   #244
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Check for shorts around the oscillator. If the clock signal is missing, the DAC won't do anything either. If you have a scope around, check the clock signal.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 16th March 2010, 01:37 AM   #245
Hi Paul,
You are right I screwed my drawing up U8 on the dwg is really U10, and U10 on the dwg is really U8.
Ray,
The ocillator is something that I'll check, I bought both the big 4 pin one and the smaller SMD crystec. I installed the SMD but had difficulty, I might have screwed it up. I don't have a scope but I'll go over everything with a powerful magnifying glass and check for shorts, and try reflowing the clock. If I don't find any thing and it still won't work, I'll try swapping the clock out for the big one.
Thanks for all of your help and patience,
PJN
Old 16th March 2010, 07:04 PM   #246
6h5c's Avatar
Ok, that's a good point, at least then you'll know the clock should be working allright.
Ray
Old 19th March 2010, 06:30 PM   #247
Does anybody have a pic of the completed underside of a working 1.5 board that they could post. I want to double check my installation.
PJN
Old 21st March 2010, 08:20 PM   #248
mikel_ann is offline mikel_ann  Germany
Check post #148
regards Michael
Old 21st March 2010, 10:27 PM   #249
Hi everyone,
I finally got some free time to try troubleshooting mu dac board some more. Unfortunately still no success but here is a run down on my findings so far.
- All the voltage regulators U8,9,10, and 11 are putting out the correct voltage, except that U10 and 11 are putting out +10.6v and -10.6v instead of 12v. but thats just a resistor change to correct.
- PCM 1794 : getting 3.3v on legs 2 & 9 as per diagram, getting 5v on 15,21,22,23 & 28 as per diagram.
- AD1899 : geting 3.3v on proper legs as per diagram.
- CS 8416 : getting 3.3v to legs as per diagram.
- U4 & 5 : getting +10.6v on leg 7 and `10.6 on leg 4 as per diagram.
- I carefully checked the board for shorts under magnification and didn't find any.
- After the above checks I removed the SMC clock and replaced it with the 4 pin canned clock.
Still won't sing. I don't have any equipment other than a DMM. Any suggestions on what I could/should check next would be greatly appreciated.
Thanks,
PJN
Old 21st March 2010, 10:54 PM   #250
6h5c's Avatar
A small suggestion: check if the RESET pins become high, +3.3V. If somehow things around U6 don't work correctly, the DAC remains in RESET state and there's no output either.
Ray
ezDAC v.1.5 Builders ThreadHide this!Advertise here!
F3 Builders Thread Melon Head Pass Labs 622 10th January 2018 07:10 PM
EZDAC is singing now!!! ezkcdude Digital Source 217 11th December 2011 07:45 PM
A-X IP Issues (split from Builders thread) tomchaoda Pass Labs 107 16th October 2011 03:05 AM
ezDAC chipsets xaudiox Group Buys 0 27th May 2009 07:45 PM
