| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#11 |
yeah! Comes with I2s and an active forum @ avrfreaks.
#12 |
Cool board - would like to see someone do an audio project with it.
Back to the topic. If you can't pull I2S off a laptop board, that's too bad. Would be a nice hack. The only easy way I know for USB to I2S is one of the BurrBrown USB DAC chips. Pretty simple and cheap. Can be USB bus powered. Limited to 32, 44.1, 48 Khz/ 16 bits. Have you looked at any of the mini-itx boards? Maybe they can do what you want within budget? |
#13 | ||
Sorry about the long delay in replying. I am learning the hard way that old laptops may (and usually do) have unexpected things wrong with them....
At this point I have given up on the original laptop hack idea - apart from the problems that people explained above, I am finding that any laptop cheap enough to make the project attractive on cost grounds probably has too many problems to make it attractive in terms of time invested. So here are a couple of remarks on replies from above. Quote:
![]() I know there's a wiki, which I plan on reading in detail, but has anyone here bought one and used it as I would like to, as the first half of an ethernet DAC? Do you like it? Quote:
Actually one of the mini- or pico-itx boards was top of my list until I saw the beagle board, but all of the above have the problem of import taxes. The avr32 board above looks like a more cost-effective option. Again, if anyone has experience I'd love to hear about it. (A related non-audio question is how do people prefer to set up an interface with the board?) Cheers Nigel |
#14 |
this board is until 96KHz, not support 192KHz
#15 |
Inside a laptop you'll probably see AC97, not I2S, connecting the audio codec.
With a bit of creativity (using a dsPIC or something) you might be able to grab the AC97 bus, pull out the primary audio signals and convert them to I2S. However, AC'97 runs at a fixed 48KHz sample rate and you're at the mercy of the soundcard driver or southbridge chipset and how well it SRC's its audio to that rate. I'd go with a USB audio solution. Easier and a whole lot more people have done it that way. |
#16 | |
Hi Guys,
Sorry, but it took a while for me to notice this old thread had been revived... While 192kHz would be nice, I'd still be pretty happy with 96kHz. In any event, do you have another suggestion for 192kHz at a reasonable price? When time and money permit I'd like to go back to these ideas... Quote:
I've done a couple of circuits with the PCM2707 (and an Alien DAC with the PCM2702) but the idea of the project was to avoid converting I2S -> USB -> I2S. The board mentioned above should allow an input from the ethernet and a direct output to a I2S DAC such as PCM1793 or PCM1794. without the intermediate USB stage. Or that was the idea, anyway... For the time being these ideas have taken a back seat to other projects (and in fact work pressure hasn't allowed me to do much diy lately) but I am still giving it some thought, and I'd be interested to read any posts people might have. Cheers Nigel |
| aux. ps for laptop using SLA | amt | Power Supplies | 4 | 10th July 2007 11:18 AM |
| Page generated in 0.09945 seconds (76.19% PHP - 23.81% MySQL) with 10 queries |
