| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Thread Tools |
#11 | |
"Every man is an artist" |
#12 |
I'd imagine AES over cat5 would not be much issue at all even without a matching series termination or "padding, it would probably make it 10m.
as for power - ethernet (PoE) can shove almost 30watts down two pairs these days. http://www.poweroverethernet.com/art...article_id=463 you do need to account for loss, but the wires can handle it. The old 802.3af spec is 15.4w at the delivery end, for max 13w at the receiving end of 100m of cable. voltage is ~48v. best bet is to shove higher voltage at lower current - and so less IR drop. IIRC, - don't quote me though - anything below 60v is considered low voltage & non-lethal... (I'm not touching it though) the IEEE geeks fight over this stuff tooth and nail - power guys, cable guys, and ethernet guys. The spec is such that cable heating from the IR drop won't significantly impact cable performance even when bundled in a large batch of cat5 cables... |
#13 | |
#14 | |
OK, thanks, thanks and thanks everyone I think I'll build a small box with XLR-to-Cat5 and vice versa and give it a listen. Jan Didden
/“If controlled, repeated tests come out the same again and again - that's Nature saying you're right" Meet me at Linear Audio |
| Thread Tools | |
| cheap cat5e cable for speaker cable | fishline | Full Range | 6 | 19th May 2009 07:42 PM |
| Cat5e Line Level Standards? | FurrorNos | Everything Else | 15 | 14th April 2009 06:14 PM |
| CAT5e Cable fun! Line level. | panomaniac | Everything Else | 3 | 25th March 2008 08:32 AM |
| Ethernet with cat5E to USB-Dac ? | lykkedk | Digital Source | 0 | 1st May 2007 06:15 PM |
| ssabripo's DIY Speaker cables Tutorial (cat5e based): Audiophile wires on the cheap! | ssabripo | Everything Else | 1 | 26th October 2006 02:32 PM |
| Page generated in 0.08063889 seconds (74.33% PHP - 25.67% MySQL) with 10 queries |
