Pulse transformers SPDIF/AES-EBU - Page 4 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 20th March 2014, 11:51 PM   #31
Eldam is offline Eldam  France
Originally Posted by bappe View Post
..NP0/C0G coupling caps is a good place to start.
Thank you for the good hints.
Does it need more than 100 nF for coupling (DC stopper)?
My understanding is the EBU's frequency wave beginn around to 100 k hz to stop near 6 M hz. So with a 75 ohms line impedance, A little more than 100 nf as coupling cap is enough (let say 200 nF...). Does it need more : I have 5 mm spacing leads bulk 1 uF COG but would you advice only a smd Cog of 100 nF or the both in // ?
If it is only for diy I would also skip the low level of spdif and keep the signal at whatever level it is and then take it down to whatever level is required by the receiver right at its input. If not using BNC I Woulrd recommend a cheap RCA rather then an expensive one, the reason being that the cheap ones are shorter and hence, presents a very short impedance discontinuity that will have a very limited influence on the transmitted signal.
that's what I saw on a chineese DAC between my Squeeze Box and CS8012 spidf receiver : the signal & gnd was directly put on the receiver (no change on the side of the squeeze box : its spidf has a cap in serie before the rca) : result was better : see it on the Lampizator site.
We often read than the line with spidf must be at least 2 meters for avoid reflexions, is it true or did you advice the shortest distance when spidf cable is used (when DIY with one of the devices or DIY the both (emitter/receiver)?
Do the 75 ohms plugs make a real difference against light RCA plugs in both scenario: with real 75 ohms line and with DIY no attenuation line (OP question) in the case of the receiver is strong enough for the voltage ? (= do the ears are able to listen to a difference?)
thank you for your help, a lot of questions, I'm sorry but I can always hear the differences when i skip a spidf cable with an other one... want to minimize this "problem". Advices are welcome .
Old 21st March 2014, 02:00 AM   #32
Originally Posted by Eldam View Post
We often read than the line with spidf must be at least 2 meters for avoid reflexions......
that seems like good idea, unless you have a transmission line that is terminated correctly at both ends. So, in general, keep the length to > 2m.
RG6 quad-shield cable works really good, so my suggestion is to at least try this cable as a cheap and excellent solution.
Nick
Old 21st March 2014, 02:06 AM   #33
Hi Eldam,
Yah, that is where it got me started on this transformerless SPDIF mod 1 year ago all because of the generous sharing at Lampizator site.
I have concern only on the amount of volt/current shorting back to the player, with the requirement to maintain the existing original circuit of the player's digital out.
The not so good part about SPDIF is that, it is real time with "non-genuine" data correction method, i believe some algorithm re-constructed data sound better than the actual data and vice verse. As such, it is best we make the spdif output as "clear" as possible to reduce interpolation filter from playing the algorithm trick~
Hi Bappe,
Thanks for the re-assurance. I read something similar that those transformer and isolation is not really that critical when the transmission is of minimum distance. Like our normal home use. Where everything is not more 2 meter apart. EMI, RFI are to only intervene without that short distance. The idea is to do it correctly. Appreciate you help answer the questuions I posted in page 2. Thanks.
Old 21st March 2014, 01:35 PM   #34
bappe is offline bappe  Sweden
bappe's Avatar
No, 100nF is quite enogh.
One is always better than 2, the key here is to keep it physically small for low inductance.
Lampizator is doing some really strange things and i would PERSONALLY stay away from most of it when it comes to data transmission.
From a signal integrity pov for the transmission, there is no need for a longer cable. If the transmission is generating reflexions (it allways does to some extent) it might be a good thing if the first reflexion does not reach the receiver when the gate is still open. A common "gate open" time is around 8nS and this would practically point towards a cable that is at least 1m or so. This is of course valid only if the main reflection is from the ends of the transmission line, if the main sources of reflexions are from both tranmitter, receiver and connectors or even the cable itself then its all just a lottery
Lets say that we need a bitrate of max 12Mbit (32*2/192k), this translates to a BW of 6Mhz, or does it really? The figure 6MHz is frequently said to be the analog BW needed for spdif but it is not. This is only the fundamental and we need around 5 times this to be able to get good signal transmission. This is sort of a rule of thumb for digital transmission but we do not want to just get by, we wan very good transmission with very little jitter contribution, right? If we transmit this 6MHz signal on a 60MHz BW line we can get the 9th harmonic in and this will give us a very nice and sharp rise and fall of our signal, going beyond this is just a waste of time and dollars It is the rise time of the signal that dictates the needed BW, not the fundamental transmission rate. So, now we know that we need an analog BW of 60Mhz in our line, a 6MHz square wave on a 60MHz line gives a rise time (10-90%) of app 6nS. In general one can get away with around 25mm of impedance discontinuity for every 1nS of rise time in digital systems, in our case 150mm. This is not valid for SPDIF since it is allot more sensitive to timing issues ie jitter. The WORST CASE jitter contribution for a discontinuity alone is related to twice its length or about 10ps for every 1mm. So use a 75Ohm connector, and if not keep it short!
No sweat diy = sharing
edit :
SPDIF is a crappy interface and the only way to get rid of its problems is to have a separate, independent clock for the DAC. No wonder that cables make a difference as it is today with HW that is not up to standard there is no telling which cable that will work best
BR,
Anders
Old 21st March 2014, 03:24 PM   #35
Thank you Anders for this serious explanation : all what I woulk like to know for a long time : I know it now and have a road map.
Thank you Extreme_booky, I have already 3 x 75 ohms digital Audio branded cables (shamed...bought in the 90s') : I will try simple & cheap TV 75 ohms quaded shelded to have experiment with short and long length with or without connector in the way Anders explain just for didactic experiments.
Thanks for sharing gentlemen
P.S. : Adrichia : Sorry for this little high jack. Did you check the max voltage input of your receivier chip to try your spidf line with your genuine source configuration without shunt to gnd ? Is a simple wirewound Z foil Rhopoint resistor as voltage diviser a bad idea ? Too much Johnson noise ?
Old 22nd March 2014, 08:08 AM   #36
Hi bappe, thanks for the great knowledge sharing.
Hi Eldam, nothing to hijack here, it is not started with me anyway the dir9001 receiver can take the full voltage from saa7345. Just not feeling comfortable letting it transmit without any protection. Not sure what kind of weird electrical effect if to run with just a resistor in series.
It is always great to see ppl doing feed backs.
Old 22nd March 2014, 08:25 AM   #37
diyAudio Moderator Emeritus
jean-paul's Avatar
The circuit seems OK. I think it is good that they RF decoupled the output GND. How is the quality of the most important part (transformer) and how does the waveform look on an oscilloscope ? If you remove that one you won't have galvanic isolation. I know many web sources claim that is not necessary but I have experienced quite a few times that galvanic isolation is making things better. This is especially valid with a source like a Squeezebox Touch. I can tell our Subbu V3 needs a transformer when coupled to a SBT. Same counts for other DACs I tried with a SBT.
Upping the 100 nF tot 220 or 470 nF would not hurt.
It's only audio. Member of the non modular PCB design committee
Old 22nd March 2014, 03:09 PM   #38
A Little Sussumu thin multilayers resistor.... which those values near the input receiver for the reflexions ? Is it the goal here ?
With 9 harmonics, if my calcul is good we have an electrical bandwidth between 100 k hz & 4 G hz... I'm asking what is the effect on a resistor with such signals? No bad with good low value as I see one between the 50 000 hz crystal and the DAC on the subbu (i suppose a ferrite bead of the same ohmic value has an another effect... ?!)
As a transformer stopping the dc on the gnd also to allow two ground loop (each on its own device): is it possible to put the equal resistor on the Gnd wire as well ?
Another subject : i remenber with the SAA75 or SA78xxx about the I2S when you remove all the RC and the caps nears the dac chip : the sound is cleaner with more resolution... maybe because of the bad quality of components on the entry level CD player 15 years ago (like the Philips cd723 which was a good player for the price and were improved with betters parts and some tweaks).
Is a good measure with scope on this case (spidf) can give a bad result with ears... and vis verca ?
Old 22nd March 2014, 04:12 PM   #39
jean-paul,
Why a 270, 470 or more value for caps as DC stopper can not do a prejudice here. I believe we must read here than such values are better than the 100 nf which theoricaly and experimentaly (scope) is enough ?
Would you say than the low end of the filter is important ? : bandwidth < at 100 000 K htz with spidf ? Are you suggesting than for ears it's better as Gary advise for example ... for ears I mean ?
My understanding :
- if I take 75 ohms : 102 nf is enough as it is a high pass filter, all under 100 K hz is removed with 6DB octave attenuation.
- if I take the ohmic entry impedance of the chip receiver (like Gary with its 470 k ohms with the W8804 chip receiver), the calcul is not he same ?
- Is there a third way (that serious people calcul with scope with each design) as for example take the RC of the line where R is the shunt resistance with each pcb and line to the Gnd ?)
I asked above if a resistor can help for reflexion (short line or line non 75 ohms) for signal &/or gnd wire. In the same spirit : is a cap needed on the Gnd wire ? Is there any garbadge sound on these under 100 K hz or none as it is spidf bandwidth signal ?
Sorry for the naive questions ? c'est juste passionnant !
Old 22nd March 2014, 04:52 PM   #40
Hi bappe,
I read some papers from Murrata.
I understand than the lower case is better for inductance as with the nine harmonics our spidf signal klimb to 4 Ghz (with 6 Mhz as fundamental).
You talked about harmonics. Is there sub harmonics too (below the fundumental) ?
COG/NPO are better for HF. But all the little smd caps with years can make some cracks with solder. there are also little piezzo electric effect and micro movements on the size of the caps and flex of the pcb which seem to make noise. I mean here hearable noise (20 hz-20 khz) ?
Is it important for EBU signal in audio device or not ?
Anyway, I understood than the low profile of the case if much more important (inductance).
My question is in fact about some special smd caps from Murrata : MK & J8 series which are "antinoise"... not in the way of hearing but in the way of electrical solutions (before a processor in computers). Does these special caps have an audible effect in serie with a signal like spidf ?
But I can not find it on mouser or Digikey !
Pfff all those questions that normal people like me have since Prometheus gave the fire to the human beings ! Et voila, we have DACs & atomics centrals ; BTW, audio is a terrible Pandora box... (what ! 2 cents of culture is not bad )
SCHOTT Pulse Transformers Extreme_Boky Digital Source 18 30th April 2011 09:12 AM
pulse transformer spdif input how? audioholik Digital Line Level 0 8th July 2009 05:19 PM
Pulse transformers legarem Digital Line Level 0 12th March 2009 03:44 PM
Selling SPDIF pulse transformer Midcom 51698 spencer Swap Meet 52 31st May 2008 01:46 AM
Copyright ©1999-2017 diyAudio
