SPDIF - Is it always the same? - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 17th February 2009, 07:15 AM   #1
poynton is offline poynton  United Kingdom
poynton's Avatar
Default SPDIF - Is it always the same?
Hi.
While reading the thread on the Philips CD723, I came across this..
The other problem is the digital filter in the SAA7378 is mediocre at best. The internal resolution is not sufficient at all, stop-band attenuation is very poor, and a -0.5dB downscaling is applied on all input signals to prevent overflows. The chip doesn't even dither before this downscaling. Thus, you will never get accurate samples from the CD out the I2S of the chip!
It made me wonder, if data is "tampered " with in some cd players, is the SPDIF output always the same ?
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 17th February 2009, 07:46 AM   #2
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
No, the SPDIF is also corrupted: read here
http://peufeu.free.fr/audio/extremist_dac/bit_accuracy/
Old 17th February 2009, 08:01 AM   #3
phofman is offline phofman  Czech Republic
The digital filter is the first stage of DA conversion. It would make sense to tap the SPDIF signal BEFORE the filter, otherwise the SPDIF stream would be the upsampled one, e.g. 352.8kHz
Old 17th February 2009, 09:48 AM   #4
poynton's Avatar
I was not refereing to te CD723 in particular but was asking the question in general.
So I guess one answer would be it depends on the chipset.
Andy
Old 17th February 2009, 09:55 AM   #5
poynton's Avatar
This is what happens in the SAA7220.
I assume therefore that, in this case, the SPDIF is "uncorrupted".
Andy
Old 17th February 2009, 10:04 AM   #6
I would dare saying the digital volume control in CD723 is more of an exception than a rule. I tested several CD players (some old Philipses and Denons) and they were bit-perfect. I cannot talk about new machines (e.g. HK CD970) with DSP etc.
Old 6th March 2009, 12:39 PM   #7
poynton's Avatar
I was interested in modding a player with the SAA7341 DAC.
In the specs, it states that the signal is cliped toprevent overflow.
So I guess the output is not bit perfect.
( The SPDIF is taken off before any upsampling is done .)
Andy
Old 6th March 2009, 11:03 PM   #8
I think the clipping block would be embedded into the noise-shaper itself, in which case an S/PDIF stream tapped off before the oversampler couldn't be corrupted by it.
Wingfeather
SPDIF on cdrom to SPDIF on Digi Crossover davidallancole Digital Source 0 11th January 2007 03:26 AM
cdrom spdif quality / sound card spdif metebalci Digital Source 0 2nd September 2006 07:16 PM
spdif out to double spdif in balthazard Digital Source 0 1st March 2005 06:52 AM
SPDIF: VCC / SPDIF which way round? rogercameron Digital Source 6 18th April 2004 10:29 AM
Spdif Akh_Ind Digital Source 3 19th November 2003 08:00 AM
Copyright 1999-2017 diyAudio
