Go Back   Home > Forums > Source & Line > Digital Line Level
Old 16th February 2009, 10:14 AM   #1
Korr is offline Korr  Russian Federation
Send a message via ICQ to Korr
Default SPDIF Output
I've got a problem with DIT4096 Audio Transmitter. I'm trying to organize optical output from my car head unit. The chip in the head unit is Panasonic MN662747RPH http://www.datasheetcatalog.org/data...N662747RPH.pdf So, I connected pins 1,2 and 3 of MN662747RPH with pin 11,12,13 of DIT4096. Crystal oscillator circuit output pin f=16.9344 MHz (59) connected to pin 6 of DIT4096. Pins 4,9,10,19, 28 connected directly to +5V from the stabilizer on the head unit plate with capacitors between pins 7 and 8, 16 and 19. Pin 7 was connected with +3,3V output of PC power supply unit (it was used also as the power supply for the system). Pins 5,8,14, 16 were connected to 0. Pin 15 was also connected to 0 to reset DIT4096. Toshiba TOTX177 transmitter connected to pin 18 (according to the scheme). In a few seconds DIT4096 became extremely hot and smoked. What was made incorrect? May be I should use some resistors for the power supply or mode selection pins?
Old 17th February 2009, 06:55 PM   #2
rossl is offline rossl  United States
rossl's Avatar
If the Panasonic chip is connected on the 5V supply it might have 5V logic levels on the Data, M clock, S clock, sync. If so, then you would need 5V on VIO pin 7. Did you check the logic levels with an oscilloscope?
All the other inputs should have a valid logic level. If they are floating they can latch up and draw excessive current.
Old 19th February 2009, 01:40 PM   #3
Yes. It's +3V on BCLK and +5V on LRCK and SRDATA. Can't measure the level on masterclock output.
Old 24th February 2011, 10:07 AM   #4
tolikas's Avatar
hi everyone,
i also tried to take straight i2s from MN662747RPH, (pins 1,2,3 and gnd)
and connect it to es9022 d/a, but unfortunately there is no sound.Any options?could it be the muted signal(pin 16)?
Donatas.
Old 24th February 2011, 03:52 PM   #5
EUVL is offline EUVL  Europe
Donatas,
I checked the datasheet of the MN662747RPH and there is no mention that pin 1,2,3 are I2S. It can be left justified (in which case you need to connect pin 4 of the 9022 to +Vs instead of Gnd), or even right justified, in which case you need to use another DAC. The input pins of the 9022 are 5V compatible, and can take 24 bit I2S, so I cannot image problems there. Also it is using 50MHz asynchronous reclocking, so clock rate has no influence.
I suggest you use a logic analyser, or try another DAC like TDA1543, to verify whether the output is indeed I2S.
Good luck,
Patrick
Old 24th February 2011, 04:28 PM   #6
The data sheet actually says "Digital audio interface (EIAJ format)", so Tx (pin 6) is also not SPDIF.
Patrick
Old 24th February 2011, 09:32 PM   #7
tolikas's Avatar
Thanks Patrick.
Old 25th February 2011, 03:56 AM   #8
May be you could have a look here :
EIAJ to I2S converter and vice versa
Patrick
Old 25th February 2011, 10:02 AM   #9
tolikas's Avatar
Are the dir9001 and cs8416 compatible with EIAJ format?it says:
Complete EIAJ CP1201, IEC-60958, AES3,
S/PDIF-Compatible Receiver...
so maybe i could use that Tx (pin 6)?
HELP! Quartet spdif output ichiban Digital Line Level 2 21st August 2009 07:45 AM
sony CDP-501 and spdif output Kathod Digital Source 6 6th March 2009 08:48 PM
Mods to the SPDIF output of a CD transport Dr.H Digital Source 14 16th July 2004 11:08 AM
Coax output circuit (SPDIF) Vinnie R. Digital Source 1 10th June 2003 04:20 PM
DIY SPDIF output on Marantz CD-46 sikkek Digital Source 5 9th October 2002 04:22 PM
Page generated in 0.09536 seconds (78.86% PHP - 21.14% MySQL) with 10 queries
