Go Back   Home > Forums > Source & Line > Digital Line Level
Old 11th February 2009, 05:39 AM   #1
Send a message via AIM to silentblackhat
Default 555 Timer Triggering Problem
I am having trouble with a mono-stable 555 timer circuit.
When I connect this to a power supply (right now it is a 120VAC to 12VDC converter), the timer turns on and then off, like it would have if it was activated by the trigger. After this, when the trigger is used, everything works perfectly like it is supposed to.
I am trying to figure out how to stop the timer from triggering right when it is connected to a 12V supply; I only want it to turn on when the trigger is used.
I apologize for the crude schematic that isn't drawn properly:
Things to note:
- This will be installed in an automobile; the Remote Module is the ground connection that the remote module makes to sound the horn; right now its on a work bench
- The charging resistor is a 100K variable resistor that only has one end and the wiper connected.
Any help is appreciated. Thank you for your time!
Old 11th February 2009, 06:32 AM   #2
Iain McNeill's Avatar
A cap to ground on the reset pin with a pull up resistor should do the trick. If not, you'll have to connect the timing cap to Vcc instead of ground.
Calculation of frequency-triggering alexpea22 Equipment & Tools 1 27th November 2008 06:56 PM
First Timer needs help mgalvez Tubes / Valves 24 17th October 2007 10:34 PM
Need help with PIC timer. Tolik Parts 9 9th May 2007 10:02 PM
audio triggering question Mindwarper Parts 2 6th December 2004 09:18 AM
Page generated in 0.07331 seconds (70.70% PHP - 29.30% MySQL) with 10 queries
