Experience with this DIY DAC ? - Page 55 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 24th May 2009, 04:56 PM   #541
McGyver is offline McGyver  Poland
McGyver's Avatar
Default Re: Anybody used a tune output on this DAC
Originally posted by shuggi67
Hi All.
First off what a great thread, read it all and the Lampizator site also, took about day and half but got through it with just a mild headache.
My question are:
1, Has anyone tried using the Lampizator tube mod or similar as apposed to the Output transformer with this DAC that can compare both sonically ? and also ease of implementation for us not so Electronically minded.
Thanks very much in advanced.
I tried using a tube output stage similar to lampizator. But transformers sounds way better than tubes when you use tube amplifier. And when you use solid state amplifier, transformers may sound even horrible. I'm going to add a cathode followers after transformers and test it with solid state amp. To be honest, I'm soldering it right now
Old 24th May 2009, 11:54 PM   #542
legarem is offline legarem  Canada
legarem's Avatar
I tried lampizator, AiKido balanced, Fet, balanced fet, Burson op amps. For me, nothing beats transformers in all systems transistor or tube based.
I modified 7 of these dacs with transformers . Before modding them with transformers, peoples used them with different circuits I made. When modded with transformers, everybody asked me to transform their dacs with transformers. They are really happy in all their setups.
Old 25th May 2009, 04:07 AM   #543
McGyver, your finding should be interesting as I would imagine some of us on this thread just use solid state amps and AV receivers, I myself am using a AV receiver and though content with the Sound of the Marantz its probably more electronically engineered for 7.1 sources i.e movies, hence the external DAC solution.
please post your results after you perform your listening tests.
Old 25th May 2009, 04:07 AM   #544
Thanks Lagarem looks like that's the way to go then, now I just need to find some transformers that are suitable.
I apologies if my reply s are a bit out of whack with all your applies but I'm still being moderated on as I'm new to the forum.
Old 25th May 2009, 04:07 AM   #545
question for Samoloko.
Did you contact the Edcor company about those Transformers, and if so have they gave you any indication that they will ship outside the U.S.
Old 25th May 2009, 04:07 AM   #546
Default Regarding audio Transformers
Couple more questions regarding Audio Transformers.
1, Should we be trying to source "Shielded" transformers ? or for this application it does not matter.
2, I'm a bit confused as a general rule is that you should not use a transformer to increase signal level by more than 25 dB, what does this mean exactly based on this project as 25dB is not very loud and how will this effect volume levels on AMP/receiver, its probably a dumb question but I had to ask
Old 25th May 2009, 05:29 AM   #547
Franz Gysi's Avatar
Shuggi
Unshielded transformers are obviously working fine in this application. Shielding is essential for low level signals.
When using 1:1 transformers there is no gain, just a very little bit of loss, depending on the transformers quality.
An increase of the signal level of 25dB means using a 1:18 transformer.
Franz
Old 25th May 2009, 07:56 AM   #548
no
I am waiting to receive dac first
Old 25th May 2009, 10:40 AM   #549
adamus is offline adamus  United Kingdom
I have a couple of these..
http://www.sowter.co.uk/specs/5069.htm
will they be suitable for this mod?
Old 25th May 2009, 10:46 AM   #550
legarem's Avatar
They should be great
A.O.S - Any experience? Keltern Multi-Way 16 26th April 2012 11:15 PM
my t-amp experience Eggzy Chip Amps 35 17th December 2005 06:29 PM
Copyright 1999-2017 diyAudio
