Experience with this DIY DAC ?
Old 18th May 2009, 01:06 AM   #491
legarem is offline legarem  Canada
legarem's Avatar
Originally posted by hoverdonkey
Legarem, I am new to this and so would be grateful if you could explain the reason for raising the cutoff if not using a preamp (I used the formula for 2x100 Ohm with 680pF, giving 1170kHz).
I use an integrated amp (Primaluna ProLogue 2) which I guess, by definition, has preamp built in. I am therefore planning to try your original filter (2x1K res, 470pF cap). Am I heading down the right path?
Sorry
I made an error
2 X 100 ohms with 4700 pf
2 X 1k with 470 pf
This gives a cut off frequency of 169 khz
Old 18th May 2009, 06:14 AM   #492
samoloko is offline samoloko  Bulgaria
legarem are Diditec really bright
for the natural sound what are your choice from best to last
are you going to compare Neutrik NTL1 or Edcore
Old 18th May 2009, 11:55 AM   #493
legarem's Avatar
As soon as I will receive and try the UTC HA108, i'll give you my results
As written in a previous message, the transformer battle will be between
Lundahl LL1690
Yamaha GA80080 (Tamura)
UTC HA-108
Little Studer uncapsulated (retried with 600 ohms load)
For my taste, I didn't like the digitecs. As they were not mine and were kindly borrowed, this is only what I had and have to write on them.
Old 18th May 2009, 04:08 PM   #494
Franz Gysi is offline Franz Gysi  Switzerland
Franz Gysi's Avatar
No no, please!
I lend them to you because I am interested in your opinion! Don't hesitate to write about your experience here.
We don't have to have the same opinion, isn't it?
Maybe this is later some stuff to discuss about?
Kind regards
Franz
Old 18th May 2009, 05:54 PM   #495
hoverdonkey is offline hoverdonkey  United Kingdom
Originally posted by legarem
Sorry
I made an error
2 X 1k with 470 pf
Thank you!
Does the 2 x 1K with 470pF filter have any advantage over the 2 x 100R with 4700pF? I understand it will be quieter (less voltage across the primary).
Old 18th May 2009, 06:28 PM   #496
legarem's Avatar
Thank you!
There's more gain with the 100 ohms resistors . The sound can be mellower with the 1K.
DIY is fun because you can taylor the sound like you want with different parts.
In the upsampling dac, the sound is a little more incicive in upsampling mode but it plays better than in non upsampling mode.
To get rid of this little problem with my system, I used Carbon composition 2 watt Allen Breadly 110 ohms resistors between the dac and the transformers.
I know that these resistors are noisy in some situations but not there. My system has 100db/1w/1m of sensitivity so noise can be a real pain when there's some.
Old 18th May 2009, 06:34 PM   #497
johnm is offline johnm  United Kingdom
johnm's Avatar
Franz are you still using 10R resistors (and nothing else) between the DAC and primaries of your Digitecs?
- John
Old 18th May 2009, 07:45 PM   #498
Franz Gysi's Avatar
Yes, John, 10R resistors.
But why don't you try yourself different values?
Franz
Old 18th May 2009, 08:19 PM   #499
I went for 2W Kiwame resisitors, which I read are smooth, so these could play nicely with the upsampling.
I have ordered some different component values for some tweaking. DAC board and Tamuras are already here, so I am looking forward to cooking soon!
Old 19th May 2009, 12:27 AM   #500
legarem's Avatar
Load the tams with 600 ohms and they will sing. Right now I can say that for the price
($35 ea) , Tams are really hard to beat.
Experience with this DIY DAC ?Hide this!Advertise here!
A.O.S - Any experience? Keltern Multi-Way 16 26th April 2012 11:15 PM
my t-amp experience Eggzy Chip Amps 35 17th December 2005 06:29 PM
