Experience with this DIY DAC ?
Old 24th May 2013, 09:48 PM   #4041
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Buy a new chip..and try
Regards Åke
Old 25th May 2013, 04:36 PM   #4042
PreSapian is offline PreSapian
can i not take readings before that? voltage reference anywhere? thx
Old 11th October 2013, 09:43 AM   #4043
padamiecki is offline padamiecki  Poland
Lightbulb warmed up
Originally Posted by fireworks View Post
Ok maybe this is a stupid question, but is a DAC like this an improvement compared to an external USB sound card like this:
E-MU Systems - 0202 USB 2.0 - USB 2.0 Audio Interface
Here in an excerpt from the specs:
Analog Line Outputs (2)
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Type: Balanced, AC-coupled, 2-pole low-pass differential filter Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. D/A converter: CS4392 Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Max Level: 6.7 dBV (unbalanced) Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Frequency Response (20Hz - 20kHz): 0.00/-0.01dB Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Dynamic Range (1kHz, A-weighted): 111dB Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Signal-to-Noise Ratio (A-weighted): 112dB Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. THD+N (1kHz at -1dBFS): -98dB (.0013%) Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Stereo Crosstalk (1kHz at -1dBFS): <-120dB
So for the line outputs SNR is 112dB and THD is 0.0013%.
How much better are these specs for the DAC discussed on this thread ?
Hi
let me share some "news"
I have been using this DAC (E-MU USB 0202) from 2006 but the sound caused listening fatigue after ~1 hour of listening.
I decided to tweak it and added additional WIMA 0.47 caps in parallel to original electrolytics on main board. To main original 2200u/10V cap I soldered 2 OSCON SEPC 270u/16V, one 1000u/63V low esr, 0.47 and 0.33u/63V WIMA. All of those operations took ~15 minutes.
The results are OUTSTANDING!
With StalthAudioPlayer using high quality audio files it plays much better than my moded cdplayers with tube I/V at the output.
The sound now is detailed, relaxed and calming with plenty of the details.
I am highly recommending this dac with tweaked power caps.
regards, Pawel
Old 10th November 2013, 11:33 PM   #4044
marshaul is offline marshaul  United States
Can these board still be found? If so, who's selling them?
If not, what's comparable that's being sold today?
I see a number of CS4398+CS8416 DACs on ebay, but none of them appear to be even similar to this board.
Old 14th November 2013, 06:30 PM   #4045
Ryssen's Avatar
This ones even got a schema,if you scroll down:
CS4398 CM102 CS8416IC DAC kit 192K/24BIT SPI&I2S Amplifier Board | eBay
Regards Åke
Old 15th January 2015, 09:59 AM   #4046
Abartels1965 is offline Abartels1965  Netherlands
Originally Posted by okasin View Post
I have pics and schematics for versjon 9, if you would like send me mail or post..
Hi Okasin,
I have this dac version V5 and would like to see the differences with V9 to mod it.
Do you have schematic and pics for me?
Alex Bartels
The Netherlands
Old 15th January 2015, 01:29 PM   #4047
Originally Posted by Richard Wright View Post
I managed to get the V8 of this DAC working at 24/192. It only works through coax though, not through the optical.
Hi Richard,
What did you do to get it working at 192Khz?
Alex Bartels
The Netherlands
Old 16th February 2015, 01:33 PM   #4048
ultravoxx is offline ultravoxx  Netherlands
There are some serious design flaws in this DAC.
First is that the contacts of the muting relay are wrongly configured (nc and no contacts are swapped), resulting in a click-sound when switching from/to mute.
Second is the relay circuitry is not able to provide the full 12Vdc coil voltage and sometimes the relay doesn't switch to unmute.
Third is that the chip on the 192KHz sample rate converter board (CS8421) is powered with 3V3 digital core where the specs mention 2.62V max.
This finally killed my upsampling chip by switching the DAC on. I modified the upsampling with a 1N4148 diode providing 2.6V at Vd (pin 3).
Altogether, the DAC really sounds nice
I've attached the jumper settings and schematics for the one who's interested (multipart zip files, remove the last .zip from the filename).
Rolf
The Netherlands
Old 7th June 2016, 12:07 PM   #4049
deadpool is offline deadpool  Australia
deadpool's Avatar
I have this Chinese board with the original CS4398 DAC wired up to the UTC-A20 transformers.
Question is which other DAC's (ebay kits etc) are worth trying with transformers, I am a little bored with the CS4398 sound...time to experiment but I still love of my UTC-A20's
'Beauty is the promise of happiness'
Old 7th June 2016, 12:11 PM   #4050
Try AK4495SEQ dac's. You need SPDIF input or I2S?
Not sure about your DIY capabilities, otherwise I would try Soekris DAM1021 with RPI/I2S
Btw, I had this same dac before too, and switched to:
Upgraded Version of Assembled AK4495EQ II2S DAC Board Support 32bit 768K Decoder | eBay
Just to compare sound between CS4398 and AK4497SEQ, AK definietly won.
Experience with this DIY DAC ?Hide this!Advertise here!
A.O.S - Any experience? Keltern Multi-Way 16 27th April 2012 12:15 AM
my t-amp experience Eggzy Chip Amps 35 17th December 2005 07:29 PM
