| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#3641 |
Thanks,
I'll get those shipped. Jensens gone.
Scott |
#3642 |
I got those same transformers,I removed the 4 caps [and power supply] connected them there and came off the secondary to rca plug gnd and the other to center,I have 2 100 R in series in the primary trans nothing in the outputs,I have a pc scope to 50 mhz no osc to there maybe sendler has a word on adding componets to the secondaries,I play mine often and no problems sound is good,you can run the sec through the relay if you get shut down or input switching noise. do run the rca's from the relay and remove the cap near the board rca's as it's on the output line too,
Happy Listening!
#3643 |
Thanks for info noSmoking.
Intel D410 mITX > Foobar > Musiland 01 USD > Gigawork DAC > Crown XLS1000 > Manzanita Ultra |
#3644 |
Post how it sounds !
I got a overall improvement over the stock set up,
#3645 |
Hey,
I was wondering since you have ran your set up most all of the ways you can would you do a walk through on what you have settled down with and are you happy with it or still wanting to tweak a little here and there Thanks for sharing !
#3646 |
I like hard drive, firewire410, digital cable 1701a, SRC2496 for upslampling, 1701a, DEQ2496 with dac swapped to AK4395 running direct out through 3.3uf Dayton foil caps one leg only no buffers or filters, RCA interconnects of Belden 1701a, 15k ladder stepped attenuators plugged right onto the amps inputs, Modified Sure 2X100 with Dayton foil input and filter caps, Wurth WE-PD 4.7uH coils, Passive heatsink, powered by MeanWell S-350-36 SMPS. Short 2 foot Foil/ Air speaker cables, Diy Usher two ways.
Scott |
#3647 |
Hi
Want to know is there anyone here have reclock their ASCR clock to better one? |
#3648 |
hi guys
is this the voltage dac? what the spec that the transformer? current rating? as i would like to custom the Output Transformer. does the dac has the current loop? can the nickel core be used? thanks in advance erwin Last edited by milen007; 10th February 2011 at 05:19 PM. |
#3649 |
I discovered that a litlle hum that I hear in my speakers went away if I connected the negaitve output of the transfomer to the chassie.Now I wonder is it a goog idea to connect the transformer sheld to the chassie to?
#3650 |
I while back I wrote about my F5 amp that went in to oschillation when I connected i to my DAC (This DAC).
Last night I connected it again and it got HOT,I hear a little hum from my speakers,so I got this idea to ground the negative output of the output trafo,and the hum went away,and the amp has been stable for 12 hours now. Why did it oschillate? |
| A.O.S - Any experience? | Keltern | Multi-Way | 16 | 26th April 2012 11:15 PM |
| my t-amp experience | Eggzy | Chip Amps | 35 | 17th December 2005 06:29 PM |
