Experience with this DIY DAC ?
Old 18th December 2010, 04:22 PM   #3541
sendler is offline sendler  United States
Default drop in
Originally Posted by gabanyayaya View Post
hi everyone
my question is possible to use a plain DIR9001 chip with Tssop28 adapter without any additional components as drop replacement for stock cs8416 receiver chip?
The DIR9001 modules are drop in for the 8416 module except for what I have said about the source selection not working right and also that my upsampling modules don't make any sound with the DIR9001 in front of them.
Scott
Old 18th December 2010, 09:19 PM   #3542
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
I dont think that would work,look at the schema of the DAC you´ll see.
Mine is working and the SCR is doing the upsampling,but then I connected the input signal direct in the DIR9001 module,don´t know if it has anything to do with it?
Old 18th December 2010, 11:05 PM   #3543
Extreme_Boky is offline Extreme_Boky
Default JT-11-BMCF vs. JT-11-DMCF vs. LL1690
so... which one should I try?
has anone compared JT-11-BMCF and JT-11-DMCF?
Boky
Old 19th December 2010, 02:21 AM   #3544
gabanyayaya is offline gabanyayaya  Malaysia
assume if source selection is not needed and upsampling modules is void, will dir9001 works?
Ryssen
is your configuration like this
dir9001 - upsampling module - scr (receiver) ?
Old 19th December 2010, 02:44 AM   #3545
Default Ebay
Boky
The JT-11- EMCF for $50 each on ebay right now are a great deal if you can get them to ship internationally. I have purchased from them twice and they were shipped out the same day.
Scott
Old 19th December 2010, 02:49 AM   #3546
Default Same board
It is all the same big Dac Board. You can interchange any of the modules on the same board which is one of the fascinating aspects of the design. I admire the way such different circuits were packaged into modules that all use the same pin connections to the main board.
Ryssen
Scott
Old 19th December 2010, 03:34 AM   #3547
Has anyone listened to JT-11- EMCF, DMCF and BMCF? Was there any notable audible difference?
How does LL1690 compare with the Jensens? I use pure silver ribbon as interconnects in all my mods and am slightly concern that Lundahls may sound too bright…. so any input here from people who actually compared the abovementioned transformers is highly appreciated.
Boky
Old 19th December 2010, 04:50 AM   #3548
true but base on your explanation i'm worried if the diy dir9001 didn't work...
have you done any mod to the cs8416 chip ?
Old 19th December 2010, 06:55 AM   #3549
milen007 is offline milen007  Indonesia
hi sandler, would you kindly post the link to the above OT? i cant find it
cheers,
Old 19th December 2010, 09:30 AM   #3550
Bill Fuss is offline Bill Fuss  United States
RIP
Boky
Legarem prefers the DMs over the 1690s. They are both excellent trafos but have very different construction. The 1690s are much costlier but that in itself doesn't make them better. The BMs are just larger. The DMs have flat response to the limits of my signal generator.
Experience with this DIY DAC ?Hide this!Advertise here!
A.O.S - Any experience? Keltern Multi-Way 16 26th April 2012 11:15 PM
my t-amp experience Eggzy Chip Amps 35 17th December 2005 06:29 PM
