Experience with this DIY DAC ?
Old 10th September 2010, 08:05 PM   #3131
Bill Fuss is offline Bill Fuss  United States
RIP
Originally Posted by McCrackers View Post
I know this has been discussed before but could anyone please comment/simplify the CS8416 PLL values issue.
What exactly needs to be done and is it a worthwhile intervention?
http://www.cirrus.com/en/pubs/errata/ER578D1.pdf
I believe that sheet is correct, it matches the latest datasheet. I changed mine as soon as I got the dac, never tried it with the other parts.
Old 11th September 2010, 03:40 AM   #3132
qusp is offline qusp  Australia
qusp's Avatar
indeed no way should the grounds be tied directly to the case. for best results tie grounds to the ground of the first main filter/reservoir cap of the power supply or center tap of the transformer and then for safety ground this should be tied to IEC ground and the case through a ground loop breaker. this last step is only for safety, there is no reason to do it otherwise as it only hurts the sound.
Old 12th September 2010, 02:49 PM   #3133
McCrackers is offline McCrackers  Canada
Thanks Bill. I believe pins 7&8 are involved but where and how exactly do you connect this filter?
Old 12th September 2010, 06:48 PM   #3134
RIP
As I recall, the components are right behind the coax input jack. I pulled the jack to get to them. From memory I believe there was a 1k R, and a .1uf cap and I can't remember what the other cap was. You should be able to trace them to the 8416 with your meter.
Old 13th September 2010, 04:32 PM   #3135
Cyan is offline Cyan  Italy
So how good this dac is? Is there anyone who fully assembles it in Europe, with dir9001 instead of the default one?
How much would be the full cost, including shipping to germany?
Old 13th September 2010, 09:17 PM   #3136
RIP
They are sold on Ebay, and one of the suppliers sells cases for them.
How good are they? What do you have now. Mine is great, I'm not looking for anything to replace it in the near future.
Old 13th September 2010, 09:20 PM   #3137
McGyver is offline McGyver  Poland
McGyver's Avatar
Which supplier sells cases for them? Can You post a link?
Old 14th September 2010, 11:13 AM   #3138
RIP
I thought I posted yesterday, must not have hit the button. I can't remember who bought one, the post was several pages back. I think he paid around $150 US with the board.
Old 14th September 2010, 12:44 PM   #3139
gabanyayaya is offline gabanyayaya  Malaysia
seams everybody is satisfied with this Chinese dac + endless modifications...but what's your though when comparing it to other breed of DAC like the EZ DAC that employs PCM1749 or the popular Quang Ho AD1865 with tube stage and those fancy shunt regulator.....???? Does anyone have been audition those fully loaded DAC before???
Old 14th September 2010, 01:41 PM   #3140
Praudio is offline Praudio
Every time I listen a DAC with a PCM1794(output well done ex: with lundhal 4/1) I get a smile in face.
Praudio
Experience with this DIY DAC ?Hide this!Advertise here!
A.O.S - Any experience? Keltern Multi-Way 16 27th April 2012 12:15 AM
my t-amp experience Eggzy Chip Amps 35 17th December 2005 07:29 PM
