| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#3111 | |
#3112 | |
#3113 |
The chips are usually used with L+, L-, R+, and R-. By selecting a mono mode, which is one of settings available in the registers, you can get L+, L-, L+, and L-. You may need to add a small, well matched series resistor, like 2 ohms or smaller (maybe none), to each output to keep one or the other from power hogging, but the signal will be well correlated in the audio band so you should be able to parallel each pair for 15.6ma which should get the transformer requirement down to 1:2. The SPDIF can simply be shared (re-terminate to get 75 ohms if you like) between two boards with one chip set to left and the other set to right channel.
Scott |
#3114 |
Ah, fair play Scott, I stand corrected. In which case this would be very interesting.
I take it you would need to custom design a PCB to mount the two chips (vero board?) If you can work this out, definitely share the layout. Rich |
#3115 | |
. K & K Audio - Lundahl Transformers, audio DIY kits and more . Too bad these Edcor trannies are a little too small. 80% nickel core and center tapped for only $26 vs $130 for an amorphous Lundahl. . EDCOR - Browse Series
Scott |
#3116 |
It might even be pretty easy to mod the stock PCM1798 module boards to stack one on top of the other in order to try mono mode with a passive I/V. Soldering another set of sockets onto the top of one board would be a piece of cake.
Scott |
#3117 |
Then my next thought is. Do we need to select mono mode at all or would stacking two stock 1798 (or 1794) boards double the current output with no other mods?
Scott |
#3118 |
Long time no speak. At last I'm back onto my DAC project. Before I get on with more mods (power supply), I want to make sure what I already have is correct and would be grateful for some info;
1) What are the audible symptons of magnetised output trannies? 2) Is my anti-ringing filter ok? I have 1000pF cap + 1K resistor in series, soldered across RCA + & - terminals (circuit diagram is here - hoverdonkey's DAC - DIY DAC). Thanks |
#3119 |
I have pooled together some of the datasheets etc relating to this board.
Enjoy; Intro/Datasheets - DIY DAC |
#3120 |
RIP
Hey, how ya doin?
Looked at your dac, was really surprised. My GA80080s are open frame, that's weird. The filter's still good. If you drop down to around 250 ohms on the primaries it will give you a little more bass reach if you need it. Nice collection of info, did you see the posts about the incorrect voltage feed on the upsampler board? |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Salas |
| A.O.S - Any experience? | Keltern | Multi-Way | 13 | 2nd August 2011 08:33 AM |
| my t-amp experience | Eggzy | Chip Amps | 35 | 17th December 2005 07:29 PM |
| Page generated in 0.19711 seconds (72.76% PHP - 27.24% MySQL) with 11 queries |
