| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#3011 |
What do you mean? Filament=heaters.
http://www.audiosurgery.beepworld.pl/dacki.htm |
#3012 |
Sorry, I'm quite inexperienced with tube designs.
For instance with the Aikido and Andrea Ciufolli's DAC-end designs, there is two supply rails: one 12V for the tube heaters and one larger one (200V) for, i think, the filament. I could be wrong. I'm just wondering if your tube stage needs any form of additional power supply. I'm guessing at least 12V for ECC88 (6922) type tubes. |
#3013 |
#3014 |
Ok Ryssen, just to clarify -
When you say "from each primary winding to ground" do you mean that the primary leads are attached to the output pins on the DAC adapter and the resistors go from the pins to signal ground. Not, like previously, the resistors are in series with the leads to the transformers, like here: ![]() And you are using no resistors across secondaries? |
#3015 |
Those resistors seems to be in series,they should be to ground,as the PCM1798 is a current output DAC it needs the resistors to ground to generate a outputsignal across them from the current.So remove the resistors,connect the wires directly to the trafo and from each wire a resistor to ground.The resistor and cap at seconary is a filter and should have nothing to do with this so leave them there.
#3016 |
Thanks Ryssen. Yes the pic above is of my old setup and used as an example of what not to do!
Thanks for the advice. Two more questions: I suppose it matters little if the resistors are connected at the DAC end or transformer end - to ground. Would a suitable ground be to return to the power supply 0V or find a nearer one to the DAC? |
#3017 |
#3018 |
Hi Ryssen,
where do you bought that dac board? thank you so much dan |
#3019 |
See this post:Experience with this DIY DAC ?
#3020 |
Thank you!!
| A.O.S - Any experience? | Keltern | Multi-Way | 16 | 26th April 2012 11:15 PM |
| my t-amp experience | Eggzy | Chip Amps | 35 | 17th December 2005 06:29 PM |
