Experience with this DIY DAC ? - Page 265 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 28th May 2010, 05:59 AM   #2641
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
I am not getting anything at the secondaries.
Is there sound when you play?
Old 28th May 2010, 07:55 AM   #2642
Originally Posted by stokessd View Post
Nope, you misread my description (Or I didn't make it obvious). There is a PAIR of OPA627's on each adapter board. You only see one, the other is tucked underneath.
Sheldon
Your board looks identical to my two; had to buy the 627s separately for one (the other's using A-20 Transformers) but they're an excellent alternative to the standard op-amps.
Old 28th May 2010, 08:25 AM   #2643
anbello is offline anbello  Italy
anbello's Avatar
@stokessd and
@suffolk tony
if you use that DAC with op-amp it's better to test that in this new board they have corrected the error explained in this post.
Ciao
Andrea
Old 28th May 2010, 08:32 AM   #2644
Thanks for the information Andrea. I read somewhere that this had indeed been corrected but can't find the relevant forum just yet - might have been a different problem.
My op-amp DAC's now installed in another system in my other home so can't check it for a couple of weeks.
Old 28th May 2010, 09:04 AM   #2645
Originally Posted by luxury54 View Post
Hi, can you detail this a little bit? the 15k resistor is put in paralel with the signal coming out on the secondaries separatelly on each channel?
also what do you mean by the positive of the secondaries? thanks
Here's my layout.. I have now changed the 15K on my previous post with a 10K and got a slight increase in treble response. Will try lower values after some time..
Sonny
Old 28th May 2010, 09:56 AM   #2646
RIP
That really doesn't make any sense unless you have high capacitance interconnects hooked up to it. Are you confident in your testing setup?
Old 28th May 2010, 01:10 PM   #2647
GerardA is offline GerardA  Netherlands
GerardA's Avatar
@sdcz
It looks like your using a soundcard to measure the DAC.
Can it be the inputimpedance of this soundcard is very low?
A serieresistor will help for this but is not the way you will listen to it.
Old 28th May 2010, 03:35 PM   #2648
No sound. But curiously, when I switched it off I had the it still hooked up and I heard a strange sort of sweep across the audio spectrum (from high to low). Maybe some caps discharging?
The transfo should be hooked up like below, correct?
+ from 4398 --> 1
- from 4398--> 4
RCA + --> 5
RCA - --> 8
EDCOR - XSM10K/10K
Maybe the + and - are mixed up, which I will check tonight. Would that matter?
Old 28th May 2010, 05:20 PM   #2649
Ryssen's Avatar
There should still be sound.
Old 28th May 2010, 07:21 PM   #2650
Got my Gigawork Dac up and running with Jensen transformers and parts from PartsConnexion. Sounds great at least as good as my Esound CD player and it is not broken in yet BUT the oversampling card went - Worked for a while then no sound. Put jumpers in and sound is back. I have heard other having problems with the oversampling card.
I may actually prefer the NOS sound but no way to tell since everything is not fully burned in. Hopefully gigawork will send me another oversampling card.
A.O.S - Any experience? Keltern Multi-Way 16 26th April 2012 11:15 PM
my t-amp experience Eggzy Chip Amps 35 17th December 2005 06:29 PM
Copyright 1999-2017 diyAudio
