Experience with this DIY DAC ?
Old 27th May 2010, 03:11 AM   #2631
stokessd is offline stokessd  United States
stokessd's Avatar
Default New Version
I just got my copy of this DAC in the mail today. Gigawork apparently has a new version of this unit. The power supply caps seem to be larger, the diodes appear to be different, and most importantly the op-amps are now pairs of OPA627's on adapter boards. A lot of the analog stage seems to have been streamlined as well. Here's a couple pictures:
Sheldon
Old 27th May 2010, 08:31 AM   #2632
fred_com is offline fred_com  Russian Federation
Originally Posted by Ryssen View Post
Ok,now i connected MJE350 the right way..that you described it.
And it works,gives 3,3v..Thanks for telling me about it!
You're welcome Glad that it worked for you. I just measured voltage between collector and emitter, and it is 3.3v, which means that transistor is working (i think ). As for why it was working the first time - if you'll look at the schematics, it's actually first MOSFET doing all the dirty work, second MOSFET is just to soften what's left from first. So, even without second transistor, board will still give out 3.3v (or whatever is set via trim pot). Again, that's just my thougths, we better ask Salas how exactly it works But that's outside of current topic, of course.
Old 27th May 2010, 06:24 PM   #2633
sdcz is offline sdcz
Hi Bill, just bought the 20k resistors and replaced the 13k on the secondary leaving the 620pf cap intact. Powered up and tested... still no change. Next thing i did was to remove the links on the caps then remove the 12 volt supply, did another test... still the same. Last thing I did was to isolate the can and internal shield but got no improvement whatsoever. I'm beginning to think that this is the normal response of the trafo with this dac. One thing I haven't tried is the 2.2nf capacitor across the primaries coupled with 220r resistors in series. I'm listening to the dac right now and there's adequate bass from 20hz onwards. The midrange and treble response are great. Thank you for your patience.. Sonny
Hi Bill, sorry for I misunderstood your instructions. Now I have tried connecting the 20k resistors across the secondaries. Also tried different values. Finally got a flat response from 10hz, dropping only by 1db from 10khz, by placing a 15k resistor on the positive of the secondaries. Is this response ok? Could we further improve on the treble response? Right now im happy of the results... Thank you so much to all who helped specially to you Bill..
Old 27th May 2010, 07:22 PM   #2634
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Hmm.the OPA627 is a single opamp,have they made a channge in the schema?
The first transistor is the current source,that sets the current,the second is the shunt element,that shunts to earth,and should set the voltage,why it worked with the transistor backwards i don´t know...
Old 27th May 2010, 08:04 PM   #2635
stokessd's Avatar
Nope, you misread my description (Or I didn't make it obvious). There is a PAIR of OPA627's on each adapter board. You only see one, the other is tucked underneath.
Sheldon
Old 27th May 2010, 08:13 PM   #2636
I think its just a mistake from Gigawork since they haven't changed their description and pricing.
Old 27th May 2010, 08:49 PM   #2637
juanitox is offline juanitox  France
juanitox's Avatar
so at the end what is better OPA627 or transfo?
CS4398 or PCM1793 ?
CS8416 or DIR2009?
to much option to take a décision..
French is not a crime.
Old 27th May 2010, 11:32 PM   #2638
Bill Fuss is offline Bill Fuss  United States
RIP
A 1db hiccup could be from anything, I would listen and not worry about it. Enjoy.
Old 28th May 2010, 12:39 AM   #2639
stc4life is offline stc4life  United States
Finally got my DAC all wired up on a board with temporary connections. Everything powers up fine and I am getting voltage at the output pins on the 4398 and at the primary connections on the transfo. However, I am not getting anything at the secondaries. I have Edcor XSM 10Ks and am using the filters as shown in the schematic in the post below, except I have 13k resistors and 680uf caps on the secondaries.
http://www.audiocircle.com/index.php...2243#msg752243
Any ideas of what might be wrong?
The coils on the transfo seem to be fine - they all read between .52 and .55 when I test them on the 20k setting on my multimeter.
This is my first DIY project so any help is greatly appreciated.
Old 28th May 2010, 05:51 AM   #2640
luxury54 is offline luxury54  Romania
Hi, can you detail this a little bit? the 15k resistor is put in paralel with the signal coming out on the secondaries separatelly on each channel?
also what do you mean by the positive of the secondaries? thanks
Experience with this DIY DAC ?Hide this!Advertise here!
A.O.S - Any experience? Keltern Multi-Way 16 26th April 2012 11:15 PM
my t-amp experience Eggzy Chip Amps 35 17th December 2005 06:29 PM
