| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#2021 |
On mine the RCA's are isolated and so are the transformers.
The '-' outputs of the DAC chip are not the same as a ground reference as It's a differential DAC chip, at least this is how I think it is (I may be wrong?) The only reference to ground in my DAC is the one from the mains socket to the 0v connection to the anolog section of the PCB. Someone can please correct me if I'm mistaken
#2022 | |
Connect the mains sockets safety ground with a thick yellow/green litz wire DIRECTLY to a big screw (why not M6, I remember a lecture by Morgan Jones) with star washers to the enclosure. The connection should not be soldered but crimped and the yellow/green wire should be longer as the mains wires (when you pull out accidentally the mains socket, the ground should be disconnected as the last wire). You can left the DAC's ground and circuit floating. Should you have some hum problems, you can connect the DAC's ground to the same M6 screw. Franz Last edited by Franz Gysi; 31st January 2010 at 08:04 AM. |
#2023 | |
In my symasyms i cant connect the safety ground to the ground of the amp, else i have strange noise on the speakers. but i dont recommend to do so, since its not 100% safe. |
#2024 | |
Thanks |
#2025 | |
![]() No hum issues here, or any other issues. |
#2026 | |
Sorry! Franz |
#2027 |
That's OK Franz, how were you to know
![]() So are you also saying that the PCB doesn't require a connection to ground? |
#2028 |
Yes, it is not needed.
However: when you connect it to ground, you will shot the fuse as soon as some circuit failure should appear. So if you have no hum problems: don't touch a running system ![]() Franz |
#2029 |
Cheers mate
#2030 |
I to have the DAC on a MDF plate and there is no hum.
Regards Åke |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| A.O.S - Any experience? | Keltern | Multi-Way | 16 | 26th April 2012 11:15 PM |
| my t-amp experience | Eggzy | Chip Amps | 35 | 17th December 2005 06:29 PM |
| Page generated in 0.15494 seconds (73.91% PHP - 26.09% MySQL) with 11 queries |
