| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#2001 |
#2002 |
"CMLI-10/600 10K:600 +21dBu Pro to consumer HiFi. Leads"
That's it? OK
#2003 |
I know this thread focus at output trannies at this moment but I still would like to share my impressions of four different opamps in the output stage.
This is my impressions graded from best to worst. 1. opa2107 revealing details and distinct impact in the lower regions. Great imaging and voices sounds natural and smooth. This is the overall winner of the four. 2. lm4562 overall good performance but a bit "shouty" in midrange and not that airy and detailed as the opa 2107 in the heights. Nice lower bass and midbass. Sounds nice or perhaps as good or slightly better than the opa2107 in plain acoustical music. 3. NE5532. This is the opamp that the dac are delivered with. It sounds quite ok but there is some lack of details in the heights and a quite boring sound in the mid-range. Can't put my finger on it but there is a bit fatigue feeling when listening to it. 4. opa2134 Very disappointed to this opamp. I've heard quite good about this one but one thing is for sure: this is not my personal flavor. It sounds dark, dull and bass is indistinct and sloppy. Have anyone tried the AD8066? That would probably be my next try. Regards H@kan |
#2004 |
Just ordered the Cinemag CMOB-2H's so hopefully l dom't have to wait weeks for them
![]() McCrackers , it'll be interesting to see how your transformers compare . Data, yeah l could'nt find much at all re the 10k stuff , just the lead info , are your Cinemags shielded , and if not would it be worthwhile isolating/shielding them? Those tumura's are supposed to be nice too hey cheers ken |
#2005 | |
Looking forward to see what you think of them ...hopefully you don't have to wait too long ![]() cheers ken |
#2006 |
#2007 |
Hay Ken.
Not shielded and I haven't noticed any issues in this regard. I have never heard the Tamara's. |
#2008 | |
Help Please! I'm hoping someone can sanity check my plans for wiring up my IEC connector, R-core (R26-34) and DAC as I'm pretty sure I've got it wrong. I haven't been able to find a good guide for the r-core (plenty for default toroids).
The advice I was provided from diyclub regarding the r-core: Quote:
Current Layout IEC E - earth? L - live? N - neutral? R-core PRIMARY Red (dot) ->115V Yellow Green (dot) ->115V Orange SECONDARY 2 x Brown (9V) 2 x Black (9V) 2 x Grey (15V) 2 x Blue (15V) EARTH 1 x Yellow/Green Proposed setup PRIMARY * Chassis earth -> IEC Earth * 1 x Red (dot) -> IEC Live * 1 x Yellow -> 1 x Green (dot) (to obtain series 230V for Australia) * 1 x Orange -> IEC Neutral SECONDARY * 1 x Grey -> DAC 13V * 1 x Blue -> DAC 0V * 1 x Grey -> DAC 13V * 1 x Brown -> DAC 9V * 1 x Black -> DAC 0V EARTH * R-core yellow/green earth -> Chassis ground I'm not sure about the 0V connections to the DAC - another poster from stereo.net suggested these needed to be connected to ground Thanks, Michael. |
#2009 |
That was me, but in that description it looks like you have no '0' taps coming from that transformer.
R-core SECONDARY 2 x Brown (9V) 2 x Black (9V) 2 x Grey (15V) 2 x Blue (15V) See by what you posted it looks like you only have active secondaries (with voltage), and no '0' taps I'm very confused? |
#2010 | |
But then you have to measure that the remaining blue and grey make 30 V AC on them. If not connect the other one of the blues to the grey one. Then the two that make 30V you connect to the two 13V connections and the two you already put together you put on the 0V connection. For the 9V you either take the two brown wires or the two black ones. |
| A.O.S - Any experience? | Keltern | Multi-Way | 16 | 26th April 2012 11:15 PM |
| my t-amp experience | Eggzy | Chip Amps | 35 | 17th December 2005 06:29 PM |
