Experience with this DIY DAC ? - Page 151 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 15th November 2009, 05:42 PM   #1501
Bassivus's Avatar
Originally Posted by ch33ta View Post
I know they are bigger, but i don't want to make a new DAC box just because of that... I'll squezze them in there somehow, even if i have to split them in half
But jokes aside, what if I put them vertically ??? Height is not the problem, I can live with a little hole on the top cover...
Do you know approximate dimensions at least, how much bigger compared to Monacor LTR-110??
I saw it on ebay a while ago with dimensions in description but can't find it anymore
Much MUCH bigger
...is I disappear. There is ONLY the music.
Old 15th November 2009, 08:32 PM   #1502
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
I am trying 2x150 ohm on the primary now,dont think Ill go any lower,thow I dont hear any clear difference compared to 2x560 ohm.
think compared to my Benchmark DAC1 this one has a little better roominfo.
And maybe better treble.
Regards ke
Old 16th November 2009, 12:10 PM   #1503
If you use lower value on the primaries (series) the sound will be much more loud, dynamic and sometimes harsh according to your setup....if you choose higher value such 1K series then you'll lack of gain little bit and sound will be much more softer.....it's up to you....to decide.
I like 100R in first place since it gives me more punch but got tired eventually....now with 1K sound a little more quiet and you have to crank up the volume to 9 o clock to have good audioble music. I think this is good since music will be more detail if we turn the pot more....IMHO...
Old 16th November 2009, 01:09 PM   #1504
GerardA is offline GerardA  Netherlands
GerardA's Avatar
Hi Gabanayayaya,
That's tru, but definitely with the monacor's there is a change in frequency response, phase and distortion. It is easy to measure with a program like Audiotester (.de). Really clear if you only change one channel and measure both. Of course different trafo's do different things!
Old 16th November 2009, 08:05 PM   #1505
Ryssen's Avatar
A RC at the out put with 1k and 2,2n
Ehumm,need help verifying that these (1K and 2,2nF)is right values for the filter at the secondaris.
Regards ke
Old 17th November 2009, 12:58 PM   #1506
Originally Posted by GerardA View Post
Hi Gabanayayaya,
GerardA
Are you testing the dac using this dac? Perhaps maybe someone here volunteering to test the A20 performance....if only I have a sound card....
Old 17th November 2009, 01:19 PM   #1507
GerardA's Avatar
Gaba...
Yes, I have the DAC connected to the PC with toslink and the output of the DAC to the Line-in of the motherboard. Samplerate of 192 kHz is possible so I guess measurements are accurate enough to make comparisons.
Would be very nice if everybody measures there DAC/trafo's this way!
Ryssen,
these values are the ones suggested before.
With the Monacor they remove the peak at 33 kHz, but then there is a small peak at 20 kHz left. Phasechanges are all over the place and I did not like the sound so I removed it. Your trafo's are different so try and see what happens.
It won't damage anything.
Old 17th November 2009, 01:48 PM   #1508
RIP
If you have a scope and signal generator you can determine the exact cap value you need. If you don't, start with 1nf (150khz) and trust your ears to tell if you need more. All trafos have different resonant frequencies.
Best, Bill
Old 17th November 2009, 03:29 PM   #1509
memofer is offline memofer  United States
Anyboby knows where I can get a case with punched holes for this dac? Thanks
Old 17th November 2009, 03:46 PM   #1510
McGyver is offline McGyver  Poland
McGyver's Avatar
like that: Projekt X Chassis 70 x 240 x 240mm with 7mm anodized aluminum faceplate | Diy HiFi Supply
A.O.S - Any experience? Keltern Multi-Way 16 27th April 2012 12:15 AM
my t-amp experience Eggzy Chip Amps 35 17th December 2005 07:29 PM
Copyright 1999-2017 diyAudio
