| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#121 | |
Regards, Boky |
#122 | |
Regards, Boky |
#123 |
Does anyone have any info on PCB layout or schematics for this DAC design?
Boky |
#124 | |
Unfortunately the schematic is a bit "schetchy" and some component values don't match what's actually put in the PCB. I haven't asked for the PCB layout, but if I was selling this DAC and trying to make a living from it I wouldn't give away the layout!
#125 | |
Kevin |
#126 |
Excellent - looking forward to doing the filter mods on mine once the final resistor values arrive. Was hoping today but looks like Monday now - grrrr! I take it low wattage resistors are fine here? Mine are only 0.25w I think...
I'm just a bit concerned with desoldering the components. I have a 50w Weller soldering iron with a small-ish tip, and a 25w Weller with a pencil tip. I'm guessing I'll have to use the 50w because of those large psu/earth traces and wriggle the leads out carefully. Last time I tried this I lifted the through-plated hole so can't say it's something I'm looking forward too Have to say though to those that are unsure whether to mod or not my DAC sounds pretty impressive already just with the filter caps removed, and running the op-amp directly to the output phonos (though your pre-amp MUST have DC blocking caps installed to do this). Looking forward to seeing how much better the proper datasheet filter mod sounds. |
#127 |
[QUOTE]Originally posted by johnm
I'm just a bit concerned with desoldering the components. I have a 50w Weller soldering iron with a small-ish tip, and a 25w Weller with a pencil tip. I'm guessing I'll have to use the 50w because of those large psu/earth traces and wriggle the leads out carefully. Last time I tried this I lifted the through-plated hole so can't say it's something I'm looking forward too Hi johnm, 1/4 watt resistors should work in the signal path; there is much debate on the sound of resistors as well... As for the desoldering process on this board, take the advice of the other guy who said that changing parts on this DAC board takes time and effort. You will need a pretty hot iron with a small chisel tip which will heat the lead holes very fast; use a thin braid solder wick to help take some of the solder away. Be careful not to try and pull the parts out unless the pad is hot enough to keep the solder melted, otherwise it is pretty easy to lift the trace lead pads. You may need to clear the holes as the other guy explains. Good luck with your mods. |
#128 |
My DAC just arrived yesterday with a CS4398. Lawrence will sell me a CS4397 unit for $35. Is the difference great enough that I sould get the CS4397?
Warning to those that are thinking about this board. Nothing is labeled except for capacitor values that seem to be wrong. The board is thick and parts are tight so desoldering looks like a headache. I'm looking at it and thinking that I just don't have time to deal with determining the layout and desoldering. I don't have all that much time to experiment so I am considering either a 6n6 tube buffer output (I can build one in about 30 minutes) or interstage transformers. I have a set of UTC A-20 and am not really sure if they will work. I'm no expert in this realm and your suggestions are greatly appreciated. Thanks and I hope all are doing well -- Mint |
#129 |
if it is not much trouble for you to build the tube output stage then don't bother with any of these operational amplifiers and analog stage modding...
i used this schematic after trying various cathode followers and stuff...this will wipe the floor in a comparison with any of yours or your friend's expensive cd-players ![]() for good results you must use 6,3v stabilised DC on the filament (not AC),and all grounds connected in a star fashion (DAC Gnd + pin9 on tube socket + the "-" of the filament + the "-" of anode supply + RCA out Gnd) also remember to take signal directly from L- and R- of the DAC since this schematic inverts the phase
== NIHIL SINE DEO - Nothing Without GOD == |
#130 | |
I have both of them and took out all the LMs from all the audio stuff i've modded till now (it is also a matter of taste) regarding the desoldering process,i think these chinese guys used the lowest quality solder they put their hands on... it's very hard to suck out the solder,but i had positive results adding some good quality solder on the joints,mixing it with the poor quality one,and after heating them up i managed to suck out the whole solder without damaging the holes good luck !
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| A.O.S - Any experience? | Keltern | Multi-Way | 16 | 26th April 2012 11:15 PM |
| my t-amp experience | Eggzy | Chip Amps | 35 | 17th December 2005 06:29 PM |
| Page generated in 0.15570 seconds (74.15% PHP - 25.85% MySQL) with 11 queries |
