Anybody know how to connect the DIR9001 with a TDA1541A in a non-os dac ?
Old 6th March 2011, 11:12 AM   #21
amc184 is offline amc184  New Zealand
amc184's Avatar
I thought I'd post on here because there is some very misleading information about I2S. When using I2S the receiver (in this case the TDA1541A) does not care how many bits the data it receives. It will simply ignore any bits that are outside the resolution it handles (the TDA1541A would ignore the eight least significant bit of data sent to it by the DIR9001).
Because the bit depth that the DIR9001 outputs in the I2S format is not critical it only offers one bit depth; the maximum it can supply. This is the same for most I2S sources.
There is no problem connecting the TDA1541A to the DIR9001.
Old 6th March 2011, 04:59 PM   #22
gaetan8888 is offline gaetan8888  Canada
Hello
"it only offers one bit depth" ?
Can you explain about that ?
Btw, is it worth it to upgrade that dac by using the WM8804 who seem better than the DIR9001 ?
I've read the WM8804 data sheet but there few things in the setting for 16 bit I2S format in hardware mode that I'm not sure.
Thank you
Bye
Gaetan
Old 6th March 2011, 10:28 PM   #23
amc184's Avatar
It only offers to output I2S format with a bit depth of 24 bits.
I'm not sure if it's worth upgrading a DIR9001 to a WM8804. I've heard good things about both. The only thing I'd recommend is the keep in mind what options each offers in hardware mode. A lot of these new devices offer a billion options, but when you read the datasheet most of them are inaccessible unless you're using a microcontroller.
Anybody know how to connect the DIR9001 with a TDA1541A in a non-os dac ?Hide this!Advertise here!
How to connect diyparadise i/v stage to tda1541A Chilli6565 Digital Source 4 12th February 2009 07:31 PM
DIR1703 vs DIR9001 cyl Digital Source 14 11th July 2008 04:57 PM
DIR9001 Vs CS8416 bou Digital Source 1 13th June 2007 01:26 PM
Dir9001 rehanabid Digital Source 0 26th January 2007 10:43 AM
how to connect the TDA1541A to the DF1706 ?? weissi Digital Source 13 12th June 2003 10:53 PM
Copyright ©1999-2017 diyAudio
