Does USB->I2S make sense ? - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 24th March 2009, 01:23 AM   #21
Originally posted by peufeu
It's part of the USB audio standard. Unless you use asynchronous isochronous mode (which needs special hardware ie not PCM27xx) your clock will be derived from USB ticks.
USB audio standard 2.0 should correct this.
I'm building a FPGA based USB soundcard which will do it the right way (ie clock in the DAC)...
That sounds like a very interesting project peufeu. I think wavelength audio, and emipiricle audio have done USB 1.1 async mode receivers using TAS1020B, but this is limited to 24/96. I'm sure there must be plenty of microcontrollers now capable of handling higher bit rates? I would be very interested in such a project - I think I read somewhere that it took a year or more to develop the s/w that they use, but I'm sure an opensource project could get done more quickly, with the right ucontroller - any suggestions? Does windows/linux support async mode directly? ie do the wavelength/empiricle DACs require special drivers? What bit rate do the windows (or linux) drivers go to?
Originally posted by BrianDonegan
USB -> I2S -> ASRC (with good clock) -> DAC. Then the USB source jitter doesn't really matter.
I don't agree. I think I read either the wavelength, or empiricle audio guy say that such USB receivers "go nuts" every 90 seconds or so. Any time you have two clocks that are not synchronizing in some way, they will drift. It's only a matter of time before they drift so far that your buffer is overrun or starved. I think I read that the USB clock can be 1% out - that's quite a rate of drift. Either you synchronize the clocks, or you "synchronize" the data with async buffer handshaking.
Originally posted by sangram
Not exactly my question, I was referring to running the 9008 in SPDIF mode (direct SPDIF input, not I2S).
I was looking for a point of view between USB->I2S (or any other I2S-converted mode) and direct SPDIF, actually.
I would think that even in the short distance between receiver and DAC, spdif could introduce some jitter, and the DAC still has to "recover the clock" to some degree, whereas the seperate clock of I2S makes this much less a problem.
Linear voltage regulator: how to make good use of "sense" and "ground sense"? NeoY2k Analog Line Level 7 6th September 2008 11:35 PM
TL, does this now make sense? Madmike2 Multi-Way 2 8th May 2005 02:39 PM
Does this make sense ? 00940 Solid State 7 27th March 2004 09:29 PM
does this make sense? nosegoblin Solid State 9 14th February 2004 02:19 PM
Does this make sense? Illusus Chip Amps 11 25th September 2003 01:59 PM
Copyright 1999-2017 diyAudio
