AK4395/4396 ultrasonic noise spectrum graphic
Here is an interesting graphic that you may not have seen. The AKM dacs feature a 2v voltage output and super low ultrasonic noise floor which enables them to run their analog output direct out to the output connector with no analog filters or buffers, still providing plenty of power to drive passive stepped attenuators. No active circuitry of any kind following them. This provides the purest, most detailed sound that I have heard. The direct out mod is very cheap to put into a DEQ2496 or various sound cards that use the AKM dacs needing only a high quality coupling cap to block the dc offset. Interestingly, I find that the sound of the 4395 has better fine resolution but the 4396 has a beautifully focused and powerful presentation.
Thanks Scott, very nice!
You seem to be not alone in your preference for the '95 over the '96.
I have found that good chips like these need only a transformer and a resistor on the outputs for spectacular results. 😀
Sowters are the cheap trannies
SunRa said:
yes I have heard of sowter being used in this position with akm parts. I was wondering about some less expensive transformers..
The Sowters ARE one of the value leaders at $120.00. Other high end transformers go way up from there. $200, $300 each! That's why I like the cap coupling method. With the right caps, Dayton foil, it sounds better and they only cost $15.00
I just like the sound of transformer coupled circuits better than caps. A matter of taste, I suppose. But many who have heard my transformer DACs like them, too.
Sowter has been mentioned, and of course there is Lundhal. Shootz! I've even used Edcor - hard to beat for $5.
My favs are still the Onectics, custom made by our own Mr. Bud Purvine, "Transformer Gypsy" and EnABL guy.
As opposed to a lesser transformer, they are much more open and dynamic.
I should have a pair of Jensen transformers here this week for testing. I'll let you know.
Remember, it is a matter of taste. Something as simple as DC blocking caps may float your boat, as sendler mentions. Whatever works. Just keep away from those opamps. :devilr:
I'm using my AK4396's analog output pins directly without any filter/opamp/buffer etc. Just a 1K resistor between my Gainclone amp. I'm not very experienced listener but I don't know how could it sound better... Maybe tweaking with power supply section and changing oscillator for low jitter. That's all.
Resistor
I assume you have a blocking cap on the input of the amp? Why the 1k series resistor?
why does everone seem to think oder 1 million cmos digital transistors and a internal cmos analog output op amp built on the compromised mixed signal process is somehow "perfect"
and immediately outside that hugely integrated mixed signal chip it is suddenly time to "get simple" to not "spoil" the sound
particularly comparing the adc internal cmos output op amp to today's fast, extended input linearity chips like AD4899 with Gilberts tanh compensated diff pair input built on a dedicated linear semi process
or any of the past decade's precision fet input op amps with 20-60 MHz GBW - some aimed at the opa627637 - or just put out the $ for the opa627
these chips won't have trouble in a properly designed I/V application - should perform far beyond NE5534 and the adc's internal analog circuitry
I meant 1k resistor between gainclone chip and dacs. It's just reuired input resistor for chip. I'm using AK4396's balanced outputs for instrumentation amplification with LM3875/gainclone chip.
This implementation permits avoiding dc blocking issues (which requiring caps in signal path) if you are not connect ground pin of dac to amp. Just + - pins.
