Understanding DC power requirement for amplifier board
Old 2nd January 2009, 03:33 AM   #1
macpaulster is offline macpaulster  United States
Default Understanding DC power requirement for amplifier board
I wonder if someone can help me understand a DC power requirement. I am looking at this amp board:
http://www.hllyelectronics.com/html/...ter_1_105.html
It says the power requirement is DC 32v-0-32v. What does this mean vs. just plain 32v DC. I want to run it on 12v battery power.
Could I use a simple 12v to 32v DC converter? Or is there some special significance to the voltage requirement being listed this way (32v-0-32v)
Forgive my lack of knowledge, a helping hand would be much appreciated.
Old 2nd January 2009, 06:19 AM   #2
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
When you see "32v-0-32v", this means the circuit requires a symmetrical supply. This is basically two 32v supplies in series with the midpoint of the two supplies being the ground reference.
If you want to use 12v batteries you will need 4 in series (6 in series might be too much for this IC).
Old 2nd January 2009, 09:07 AM   #3
jitter is offline jitter  Netherlands
jitter's Avatar
Default Re: Understanding DC power requirement for amplifier board
Originally posted by macpaulster
[B]I wonder if someone can help me understand a DC power requirement. I am looking at this amp board:
See below for a graphical representation of what theAnonymous1 wrote.
You'd need two DC/DC converters, or one with symmetrical outputs.
But a thing to beware of is the power consumption of the amp you are using. Simple DC/DC converter(s) are pretty limited in power output and won't be able to supply the amp with enough current.
I'd use a a type of power supply as found in car power amps.
For more/better answers move this thread to the right place (like amplifiers> solid state or chip amps).
Old 2nd January 2009, 09:37 AM   #4
R.I.P.
build a transformer, rectifier and smoothing capacitor dual polarity power supply.
Ignore that >150W guide for PSU capability. That's equivalent to >2.3A
You need a supply that can deliver a continuous rating of 120 to 240VA. It must also be able to supply transient peak currents approaching 20Apk if you use two 8ohm speakers fed from +-32Vdc.
Note the 35-0-35 limit noted on the PCB. This is a worst case maximum voltage rating. Do not exceed it even when mains is running at maximum tolerance.
regards Andrew T.
Old 2nd January 2009, 10:46 AM   #5
Thanks for the info. Seems like a 32v-0-32v amp isn't practical for battery power as the whole point is portability and ease of charging with 12v.
Old 2nd January 2009, 11:45 AM   #6
jitter's Avatar
You may be interested in this module then. It's not as powerful but runs off a single 14.6 V PSU (= typical voltage on a 12 V car battery with the engine running). It should work fine on 12 V (but with a slightly lower max. power output).
Old 2nd January 2009, 11:58 PM   #7
Jitter, actually i AM using that board for the mains but was looking for something a little more powerful for the sub. They also offer a bass amp which I was considering:
http://www.hllyelectronics.com/html/...ter_1_104.html
Power requirement is not listed but I can only assume it's something like 32v-0-32v just like the other amp, so it likely would create the same challenges for battery power...
Old 3rd January 2009, 12:20 AM   #8
jitter's Avatar
It see two big caps and three screws for the PSU connection. That's got to be for symmetrical PSUs.
You could still use that. The sub has probaby only one woofer, right? Maybe it's possible that both channels can be bridged to get double the power (but then mono, of course).
Old 3rd January 2009, 10:01 AM   #9
I asked the manufacturer about bridging and they said no, it won't work.
For my project I just got two of the 20w x 2 boards:
http://www.hllyelectronics.com/html/...tter_1_97.html
And I'm using a dual voice coil sub. I'm hoping that will work well, but the sub will only see 40w. But since I'm using battery power, that may be a blessing. I'm curious to see how long it will go. Battery will be about 10 Ah.
Old 3rd January 2009, 10:14 AM   #10
R.I.P.
dual voice coil driver.
Use a power amp dedicated to each VC.
regards Andrew T.
Understanding DC power requirement for amplifier boardHide this!Advertise here!
Power supply requirement for Class D amp. e_fortier Class D 2 29th December 2008 10:19 PM
Output Inductor Power Requirement gearheadgene Class D 6 28th February 2007 03:47 PM
Power supply requirement help araven Power Supplies 1 8th August 2006 07:26 PM
Power Amplifier PCB-layout / Board design Jan Dupont Parts 4 10th February 2004 08:35 PM
Minimum power requirement Seville Multi-Way 3 3rd December 2001 01:15 PM
