Go Back   Home > Forums > Source & Line > Digital Line Level
Old 30th December 2008, 05:05 PM   #1
Default MF XDAC V3 connected to a pc motherboard
Hi!
I need some advice
I want to use the standalone Dac converter XDAC V3 from musical fidelity whith my pc. the problem is that the soundcard embedded on the motherboard has an spdif output, but it is not connected to an external coax rca output.
From the instruction manual of the motherboard (see photo enclosed) I suppose that a coax output can be connected using pin 5 to ground and pin 3 (labeled spdif) connected to the center wire of the coax cable, it is correct?
and, this way, the output inpedance are the 75 Ohms that the XDAC likes?
thanks on advance.
by the way, has anybody tried the inexpensive new outboard converter from MF, the VDAC?
A cold amp is a sad amp... I like them warm at least
Old 30th December 2008, 06:20 PM   #2
jitter is offline jitter  Netherlands
jitter's Avatar
Default Re: MF XDAC V3 connected to a pc motherboard
Originally posted by karellen
[B]Hi!
I need some advice
Yes, that would seem to be the correct way to connect the output to your DAC.
Assuming that the motherboard manfacturer adheres to S/PDIF standards, yes. I don't think that the optional bracket with the RCA connector(s) will have anything else than wiring and connectors.
Note that the AC3 audiostream from DVDs through the S/PDIF output will only work on suitable (Dolby Digital) decoders. Most likely the audiostream on S/PDIF will be 2ch (stereo) @ 48 kHz as default, so that should not be a problem.
Old 21st January 2009, 01:11 AM   #3
Default it works, well, almost
Hi!
I've made the connection and the DAC locks, and there is sound
but...
there is a strange and nasty digital noise with the music, not a hiss, click or so on, but something related to the music, at a lower level.
it depends on the track of music, most of them have it, but not all.
some of them are mp3, other are flac, or wav, and it happens with several players, winamp, vlc, wmp...
in a nut shell, I haven't found a correlation between noise and filetype or player.
any help?
by the way, when the noise is absent, the sound is really incredible compared with the pc soundcard!
Old 22nd January 2009, 09:40 AM   #4
Default problem solved
not fully sure, but the problem seems to be the open case of the pc
now it works just fine
the xdac locks on 44,1 khz and 96 khz
toroid near a computer motherboard. neutron7 Parts 3 6th November 2007 02:11 AM
Nice motherboard DragonMaster Everything Else 1 4th February 2007 07:02 AM
Asus Motherboard herm Everything Else 5 3rd January 2007 09:11 AM
How big Harddrive can I use with my motherboard? Christian Digital Source 44 5th August 2003 07:03 AM
Copyright ©1999-2013 diyAudio
