Technics SL-PG400A - SPDIF ?
Old 27th December 2008, 07:58 PM   #1
101dm is offline 101dm  Germany
Default Technics SL-PG400A - SPDIF ?
Hello,
I got a old Technics CDP with CDM4/19 Laserunit.
To use it as a Transport (...just for fun - normally I use my Shigaclone ) I need a SPDIF-output.
The Player has got only a optical-output.
Is there a (easy) way to get SPDIF out of that Box???
Thank you and greetings
Markus
Old 28th December 2008, 09:22 PM   #2
...no Idea???
Old 28th December 2008, 11:12 PM   #3
jitter is offline jitter  Netherlands
jitter's Avatar
You say you have a shigaclone. If you made it yourself, you probably already know how. I'm not sure, but I think the signal of Dout in your 'clone is no different from the signal in the Technics driving the Toslink transmitter...
Old 28th December 2008, 11:38 PM   #4
Hi Jitter,
yes I made the clone by myself.
The description from the Pro`s in the "Shigaclone-Post" is very good and it helps beginners like me to do such fine stuff...
AND the SPDIF on the Shigaclone PCB is marked as Dout!
Its not marked on the Technics-PCB.
I`ve read Toslink is the "same" Signal as SPDIF an if you have Toslink you also have SPDIF - but where can I pick it up?
Maybe you can help me further?
Greetings
Markus
Old 28th December 2008, 11:49 PM   #5
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
simply said - SPDIF is driving "LED" in Toslink
find any schematic where both are drawn , and you'll see
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 29th December 2008, 12:09 AM   #6
...sometimes it`s just easy
THANK YOU for that!!!
Markus
Old 29th December 2008, 12:48 AM   #7
jitter's Avatar
Ah, the coin has dropped .
What I'd do is rip out the Toslink transmitter and check the signal level on the pad where pin 4 used to be (datsheet).
I'm expecting it to be the same as the 'clone's. If so, I'd use the same value resistors as needed for the Shigaclone to get correct S/PDIF signal level and 75 Ohm output impedance..
BTW, I'm going to build one too, today I ordered a RC-EZ51.
Old 29th December 2008, 05:14 PM   #8
Hi Jitter,
thank you!
...and you will love it!!!
Old 29th December 2008, 06:33 PM   #9
jitter's Avatar
I read about 90% of the Shigaclone thread and it seemed to me that everyone has a very positive experience with this cheap little transport (barring some broken stuff due to mistakes)! My method of upgrading will probably be slightly different, though.
As experiment, today I converted a Toslink input to coaxial input on my old (and partly broken) CD-recorder. That's a little more work than converting a Toslink output to coaxial output due to the fact that the S/PDIF signal needs to be amplified to 5 Vpp, but still pretty easy. You just need a few more parts.
I'm browsing the internet for a really affordable secondhand DAC to get my Shigaclone project on the way...
I stumbled upon a multiple input Denon. The weird thing of this DAC is that 3 of the 5 inputs are Toslink . It's a pretty standard quality DAC, but it already has an upgraded analogue output section. If I decide to buy it, I'll first convert the optical inputs to coax (hence my experimenting today) and maybe apply some more tweaks I found on the internet for this particular model.
Old 29th December 2008, 11:31 PM   #10
I picked up S/PDIF from my TECHNICS!
It`s VERY easy...
@Jitter:
Some people (me too) using the Shigaclone with a NOS-DAC.
I got the one from Scott Nixon and I'am very satisfied.
There are many schematics in the Internet with the Philips TDA 1543 DAC (needs no "output-stage") so you can DIY one just for testing it.
Maybe you like it!?
Greetings
Markus
Technics SL-PG400A - SPDIF ?Hide this!Advertise here!
SPDIF on cdrom to SPDIF on Digi Crossover davidallancole Digital Source 0 11th January 2007 04:26 AM
cdrom spdif quality / sound card spdif metebalci Digital Source 0 2nd September 2006 08:16 PM
spdif out to double spdif in balthazard Digital Source 0 1st March 2005 07:52 AM
SPDIF: VCC / SPDIF which way round? rogercameron Digital Source 6 18th April 2004 11:29 AM
SPDIF to AES/EBU Kari Digital Source 4 22nd February 2004 12:29 AM
