Volume control in the dac output stage
Old 23rd December 2008, 02:50 PM   #1
Telstar is offline Telstar  Italy
Default Volume control in the dac output stage
Greetings,
This idea is blinking in my mind.
I'm going to build a DAC based on Borbely dac age
http://www.borbelyaudio.com/pics/New_DAC_Age.pdf
and I want to have volume control in the DAC, which would be the easiest way imo to implement it in my chain.
First question, would it be within, before or after the output stage?
Second, my f3 power amp needs current, so what kind of conversion should be done?
Third, because i want remote and display, i was considering Tent VC:
http://www.tentlabs.com/Products/page31/page31.html
Fourth, I'm considering the lightspeed and i would probably prefer it to Tent attenuators. mmh.
Any suggestion and idea are welcome.
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 24th December 2008, 04:18 PM   #2
hifimaker is offline hifimaker  United States
hifimaker's Avatar
One aspect of the Borbely DAC you referenced that I don't like is how he summed the differential output and then used a phase inverter recreate differential output. The advantage of using 4 1704's is so a phase splitter does not need to be used.
The attenuator goes after the DAC buffer and before the F3. If your attenuator has a buffer, then you maybe able to bypass the DAC's buffer to strip out circuitry in the signal path.
Other topologies to consider using:
* Pass x-BOSOZ or BOSOZ with CCS to convert the true balanced differential DAC output to single ended with a volume control on the output, and then to the F3.
* Pass B1 buffer after the summed output of the DAC to the F3.
-David
Old 24th December 2008, 05:08 PM   #3
Thank you for the reply, David. and merry christmas.
I do not plan to use it straight as is, for instance i dont need balanced and i want to disable (remove) all filters and its switch.
I think borbely makes different output stages, which one do you suggest (not limited to his ones)?
I'm also thinking to double the dacs number and use 4 per channel, in single-ended mode.
-David
I'll either use George's lightspeed mk2 + a B1 buffer or a different version of LDR that has already a buffer(s).
In the first case my idea was to incorporate the lightspeed in the dac output stage (henche the thread title), with addition of a remote and display for the volume such as Tent labs.
Volume control in the dac output stageHide this!Advertise here!
DVD/CD player with Balanced XLR output and volume control Freddie Everything Else 9 2nd March 2015 02:58 PM
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Input selection and volume control with balanced output, transportable? jmaurer Solid State 0 11th August 2007 07:08 AM
Help me regarding very low Supply Ripple output noise DC volume control unit electronist Parts 0 31st December 2003 09:29 AM
Aleph L output volume control wareham Pass Labs 1 19th April 2003 02:06 PM
