| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#11 | |
"If you don't like funerals don't kick sand in ninja's face." |
#12 | |
#13 | |
#14 | |
Anyway, to original poster, the OPA1632 was made for exactly this type of thing. It's the easiest, simplest and best solution you will find without going to the extremes of complexity. |
#15 | |
#16 |
Little bit of caution if you're using figure 13.
If the source impedance of the + and - inputs aren't the same, ie. if the - input is grounded (0 ohms) and the + input has a non-zero source impedance, you'll get a DC offset on the output. Poke an op-amp buffer on the + input to get around this. A single OPA2134 or similar should suffice for both channels. |
#17 |
Thank you all for your suggestions and inputs ..... It clarified issues that I have to pay attention
To the end of this A/D project that I'm doing - any of you who knows how I can transfer the 2 channels of 24 bits/192 khz via USB to my laptop? I'm looking for a straightforward chip solution that accepts the output from the PCM 4202 and converts it to USB in a way so that the laptop recognizes that a new USB device is present (with the characteristics necessary for audiosignal transmission). My aim is to not have to do any programming .... Any ideas? Thanks Jesper |
| Driving differential ADC with single-ended source | suzyj | Digital Line Level | 9 | 19th May 2009 08:39 PM |
| testing a single ended or differential topology | Stefanoo | Pass Labs | 11 | 26th October 2007 06:59 PM |
| Converting from single ended parafeed to differential | dsavitsk | Tubes / Valves | 9 | 12th July 2007 07:46 PM |
| Volume control + Single Ended -> Differential Amp | koolscooby | Solid State | 2 | 6th April 2004 12:50 AM |
| Differential to single ended... | Bas Horneman | Tubes / Valves | 21 | 2nd April 2003 03:05 PM |
| Page generated in 0.09735 seconds (77.01% PHP - 22.99% MySQL) with 10 queries |
