single-ended to differential?
Old 10th December 2008, 05:37 PM   #1
gentlevoice is offline gentlevoice  Denmark
Default single-ended to differential?
Hi DIYs,
I have an IC with a differential analog input and I will be connecting a single-ended signal to this input.
My approach will be to ground the VIN- of the IC and connect the positive signal part of the single-ended input to VIN+ on the IC. And then connect the grounds.
Just want to hear if there is a better way....
Thanks,
Jesper
Old 10th December 2008, 05:44 PM   #2
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
What's the IC?
Old 10th December 2008, 05:54 PM   #3
PCM 4202 - A/D converter from Burr-Brown.
http://focus.ti.com/lit/ds/symlink/pcm4202-ep.pdf
Jesper
Old 10th December 2008, 06:18 PM   #4
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
I don't think that's such a great idea; it would kind of defeat the purpose of using such a high end ADC. If you look in the datasheet it recommends using an OPA1632 as an input buffer. You can connect the negative input of the OPA1632 to ground for single ended input.
Old 10th December 2008, 06:26 PM   #5
Default @anonymous
uhuh, seems I'm opening up for more than just the quick advice I was looking for....
As far as I remember from the theory I learned some years ago not connecting it in differential mode will cost 3 or 6 dB SNR...
Are you thinking of something else when you say
Best Jesper
Old 11th December 2008, 02:28 AM   #6
Reduced CMRR perhaps?
Old 11th December 2008, 06:17 AM   #7
Cauhtemoc is offline Cauhtemoc  Sweden
An opamp would be the simplest choice. Check page 23 of the PCM4202 datasheet.
Old 11th December 2008, 07:24 AM   #8
mako1138 is offline mako1138  United States
Note that the analog inputs have an absolute max range of -0.3V to (Vcc+0.3V). So if you grounded one input, the other would only be able to swing 0.6 Vpp, assuming a symmetrical audio signal. Is that enough for your purposes?
Old 11th December 2008, 12:50 PM   #9
Figure 14 on page 23 of the datasheet is a buffer for the common-mode reference voltage, not the inputs.
That would be -0.3V to 5.3V (assuming Vcc is 5V), not -0.3V to 0.3V.
Old 11th December 2008, 07:24 PM   #10
I was obviously refering to figure 13.
single-ended to differential?Hide this!Advertise here!
Driving differential ADC with single-ended source suzyj Digital Line Level 9 19th May 2009 07:39 PM
testing a single ended or differential topology Stefanoo Pass Labs 11 26th October 2007 05:59 PM
Converting from single ended parafeed to differential dsavitsk Tubes / Valves 9 12th July 2007 06:46 PM
Volume control + Single Ended -> Differential Amp koolscooby Solid State 2 5th April 2004 11:50 PM
Differential to single ended... Bas Horneman Tubes / Valves 21 2nd April 2003 02:05 PM
Copyright ©1999-2017 diyAudio
