Zero DC-offset TDA1543
Take a closer look;)!
The TDA1543 is fed with +/-2,5VDC making the output 0V.
Zero DC-offset adjustment is with Vref resistor.
The digital input is therefor "level translated", see schematic!
My idea was to feed it with +/-4V and skip the output filters and OPs. As my output transformers can take no DC at all this must be a possible way to fix it.
My concern is how to look at the output loading as there will be no DC-current through the I/V-resistor, only AC?
Sorry Lars, I totally overlooked the dual supply for the TDA1543.
I am not sure the offset will be low enough for IV-transformers. Probably the Sowter 8347 can take it; the 9762 not!
