Go Back   Home > Forums > Source & Line > Digital Line Level
Old 5th December 2008, 09:13 AM   #11
QSerraTico_Tico's Avatar
Originally posted by revintage
Take a closer look!
The TDA1543 is fed with +/-2,5VDC making the output 0V.
Zero DC-offset adjustment is with Vref resistor.
The digital input is therefor "level translated", see schematic!
My idea was to feed it with +/-4V and skip the output filters and OPs. As my output transformers can take no DC at all this must be a possible way to fix it.
My concern is how to look at the output loading as there will be no DC-current through the I/V-resistor, only AC?
Sorry Lars, I totally overlooked the dual supply for the TDA1543.
I am not sure the offset will be low enough for IV-transformers. Probably the Sowter 8347 can take it; the 9762 not!
Old 5th December 2008, 09:35 AM   #12
revintage's Avatar
Hi Quirck,
As I see it offset is adjustable to zero V so that part of should be no problem.
I am am into what Per-Anders wants to explain but I want a simpler solution without more sand. ie. using a transformer with suiatable DCR as I/V loading.
Brgds
Lars
TDA1543 dac dariusku Digital Source 3 31st March 2006 07:38 PM
Where to buy tda1543 RAYSIMMONS Parts 1 17th May 2004 05:03 AM
TDA1543 Non OS DAC jean-paul Digital Source 83 22nd January 2004 11:27 PM
TDA1543 dac Rotellian Digital Source 9 12th September 2003 09:38 PM
TDA1543- How many to use? Dr.H Digital Source 3 6th March 2003 12:46 PM
Page generated in 0.06103 seconds (77.46% PHP - 22.54% MySQL) with 10 queries
