Monica 2 + gain stage; High pitch noise problem
Old 27th October 2008, 03:00 AM   #1
spacemen12 is offline spacemen12  Sweden
Default Monica 2 + gain stage; High pitch noise problem
I have a high pitch noise commin out of my DAC. I want to get rid of it, but don't know how. Here is how I found that it is from my dac.
Set-up 1:
cambridge 540c v2 (as transport), Monica 2 + Rudolf Broertjes' SS I/V Gain Stage as Dac, passive preamp (resistive serie shunt), gainclone, fe103e in blh
set up 2 (modification of the first set up):
cambridge 540c v2 (as transport), Monica 2 + Rudolf Broertjes' SS I/V Gain Stage as Dac, cmoy, Sennheiser HD250 II
My psu for the dac is an smps that I regulate at 12VDC (Monica) and 15VDC (gain stage) using lm78**. The cmoy is battery powered (18VDC).
I added "Newava Technology S22083 1:1 pulse trans" between the RCA plug and Monica 2.
I have the noise with the two set up. with the passive pre, it is there all the time. With the headphones, is is there only after "3" on the volume pot (zero is at "7").
It doesn't matter is the coax from the transport to the dac is plugged, the noise is there.
I only have a multimeter to test, but I don't know what to test.
Monica 2 + gain stage; High pitch noise problemHide this!Advertise here!
High Pitch Noise in tweeters bigrubes24 Car Audio 2 28th April 2005 12:39 AM
Low value IV resister followed with high gain amp stage?[tda1543] setmenu Digital Source 10 27th September 2004 01:14 PM
Balanced line stage gain problem ! lykkedk Pass Labs 9 19th June 2003 07:24 PM
HELP! High gain, low noise fet advice needed! Lenin Swap Meet 17 21st February 2002 12:08 PM
Help! High gain, low noise fet advice needed! Lenin Solid State 1 16th February 2002 01:53 AM
Copyright ©1999-2017 diyAudio
