Clock Jitter Cleaners
Old 29th October 2008, 09:08 PM   #31
Guido Tent is offline Guido Tent  Netherlands
Originally posted by excelon
it will be only a board, perhaps 250 mm. long in the final form though the digital circuitry will take less space. There aren't any cables, only (paired-for differential, same length) PCB tracks. I'll try to keep them as short as possible without using vias. Also, I'll isolate these drivers from the rest of chips (having it's own PS) so CPLD isn't a solution anymore...
thanx
It will depend on the jitter requirements of the DAC / ADC, if LVDS is allowed, the analogue output noise level may get worse.
A good single ended coax will do a better job, for sure
best
Guido Tent
www.Tentlabs.com
Old 30th October 2008, 12:58 AM   #32
tritosine is offline tritosine
how far the "proaudio" style Wordclock can travel safely using the standard BNC termination? Sadly the grimm clock missing these details and I read all kinds of stuff on the net. I want about 5-10 meters, cause PC with wordclock io on soundcard is "kicked out" of the room.
Old 30th October 2008, 08:11 AM   #33
excelon is offline excelon  Europe
the DAC uses four PCM1794A chips for a stereo configuration. Every DAC will need three synchronous clock signals: I2S Bit-Clock/Word-Clock and System Clock. Fortunately, there are no ADCs on that board.
A very good ideea though, I must admit, it's an exotic one. Besides that... it would need too many cables/connectors for every DAC chip.
Best regards!
Old 30th October 2008, 10:39 AM   #34
The allowed cable length is not a property of the wordclock generator, "endless" lengths of coax can be driven, the transmission losses unfortunately reduce the lenghts to practical ones, but 10 meter is no problem: Look at the cable specs.
best
Guido Tent
www.Tentlabs.com
Old 30th October 2008, 10:40 AM   #35
Best regards!
LVDS using PCB traces is more exotic, in my perception
Forget about the connectors, coax can be solder connected to the board.
Why the huge distance between source and DAC chips ? Move the DACs to where you need them, and extend the analogue output signal: Less hassle
best
Guido Tent
www.Tentlabs.com
Old 30th October 2008, 02:51 PM   #36
quantran is offline quantran  Viet Nam
Send a message via AIM to quantran Send a message via MSN to quantran Send a message via Yahoo to quantran
I have tried to order one but no response.
Originally posted by 00940
muckrake: a clock costs 25 (30 with vat) at tentlabs. Not a bad deal for a audio specialty shop. And you don't have to buy 100.
Quan Tran
Old 30th October 2008, 03:28 PM   #37
No response yet, I am way behind in answering Emails but will get back to you soon
best
Guido Tent
www.Tentlabs.com
Old 30th October 2008, 08:40 PM   #38
well, in this case we have different opinions about "exotic" implementations. Excluding the care for PCB layout, I thing that differentialing is still a good approach with good benefits.
yes, I'll do that: it's one of the main board's constraints. I'll make a block schematic for better understanding. In the end, I guess that the distance between DACs and clock source is less than 250 mm long.
best
Old 31st October 2008, 08:20 AM   #39
best
Differential signalling only works as long as the full path is diffeerentiasl. Given all parasitics on biards, that is a ahard job. Coax is much better - been there, done that.
And you "should" place the clock close to the DACs, that is rule number one with DAC design.
best
Guido Tent
www.Tentlabs.com
Old 31st October 2008, 03:44 PM   #40
coloradosound is offline coloradosound  United States
Nice to see the clock expert find this thread!
Hey Guido checked your site and wondering if you know
freq. for Denon DVD-2910 as listing is just for CD transports/
players. Also have a Theta Data II that I'm not sure if it's worth
doing new clock or if it is more critical in outboard DAC?
Clock Jitter CleanersHide this!Advertise here!
16.9344MHz LOW JITTER CLOCK KIT... bleachershane Digital Line Level 146 4th July 2010 02:17 PM
low jitter clock help needed atcgreg Digital Line Level 10 9th June 2009 07:58 AM
Another clock idea for low jitter Bernhard Digital Source 7 29th October 2004 05:05 PM
Clock in RME AD/DA 1nS Jitter! fmak Digital Source 7 31st May 2004 08:45 PM
