I was searching for info on a CDP on the ole' net..and I came across this. A DAC list. Wow. Mods, please erase if you feel it is not a resource you want around, or if it is here already....
CD-players D/A converters
ACOUSTIC RESEARCH CD-07 SAA7220
ACCUPHASE DP65 8x PCM1702 (4/ch)
ACCUPHASE DP85 AD1853
ACCUPHASE DP90 PCM63
ADC CD 250XR PCM54
AKAI CD37 PCM67P
AKAI CD55 AD1856
AKAI CD57 PCM67P-J
AKAI CD69 PCM63
AKAI CD73 PCM56
AKAI CD93 PCM56
AKAI CD-M839 PCM56
ALBA CD420 PCM54
ALCHEMIST NEXUS APD32A 2x TDA1549
AMC CD60 PCM1716
AMC CD8A MN6474 (Technics MASH)
AMC CD8B PCM1716
ANTHEM CD1 PCM1702
ARCAM ALPHA TDA1541A
ARCAM ALPHA 5 TDA1541
ARCAM ALPHA 5 PLUS TDA1541A
ARCAM ALPHA 6 SM5864
ARCAM ALPHA 7 PCM1710
ARCAM ALPHA 7SE PCM1716
ARCAM ALPHA 8 SM5864AP
ARCAM ALPHA 9 dCS RingDAC
ARCAM ALPHA PLUS TDA1541A
ARCAM CD72 PCM1716
ARCAM CD92 dCS RingDAC
ARCAM DELTA 70.2 TDA1541AS1 (single crown)
ARCAM DELTA 70.3 SAA7350
ARCAM DELTA 110 2x SAA7321 (1/ch)
ARCAM DELTA 110.2 2x PCM67P-J (Sync Lock)
ARCAM DELTA 270 PCM69
ARCAM DELTA BLACK BOX 1 TDA1541A
ARCAM DELTA BLACK BOX 2 TDA1541A
ARCAM DELTA BLACK BOX 3 4x SAA7321 (2/ch)
ARCAM DELTA BLACK BOX 5 2x PCM67PJ (Sync Lock)
ARYE CX-7 PCM1738
ARYE D-1 PCM1704
AUDIO ALCHEMY ENGINE v3.0 AD1862
AUDIO ANALOGUE MAESTRO AD1855
AUDIO INNOVATIONS ALTO PCM1716
AUDIO NOTE CD-1 PCM1710
AUDIO NOTE CD-2 AD1865
AUDIO NOTE DAC-3 PCM63
AUDIO RESEARCH CD1 SAA7341
AUDIOLAB 8000 CD CS4329
AVI SC2000MC PCM63
BLAUPUNKT CP2650 PCM54
BLAUPUNKT CP2990 PCM56P
CAMBRIDGE AUDIO CD1 TDA1541
CAMBRIDGE AUDIO CD2 4x TDA1541
CAMBRIDGE AUDIO CD3 TDA1541A
CAMBRIDGE AUDIO CD4SE CS4327
CAMBRIDGE AUDIO CD6 TDA1305T
CAMBRIDGE AUDIO D500 CS4327
CARVER SD/A 450 MN6474
C.E.C. 530CD2 Y3015
C.E.C. 680CD LC7881
CONDOR CD950 YM3020
CONSONANCE CD 120 CS4396
COPLAND CDA277 PCM63
COPLAND CDA288 PCM63-K
CREEK CD50 MkII CS4396
CROWN AVC-9500 AD1864
CROWN CD2111R LC7881
CYRUS CD7 PCM1716
CYRUS dAD1 TDA1311
CYRUS dAD3 TDA1305
CYRUS dAD3Q AD1861
CYRUS dAD7 AD1861
DENON DA-500 PCM1702
DENON DCD-435 PCM1716E
DENON DCD-480 PCM61
DENON DCD-485 PCM1735
DENON DCD-500 PCM54
DENON DCD-580 PCM67P
DENON DCD-590 PCM61
DENON DCD-615 PCM61P
DENON DCD-635 PCM61P
DENON DCD-650F PCM1700P
DENON DCD-655 PCM1702
DENON DCD-660 2x PCM61
DENON DCD-680 PCM69A
DENON DCD-685 PCM1702
DENON DCD-690 PCM61
DENON DCD-695 PCM61
DENON DCD-700 PCM54HP
DENON DCD-725 PCM61P-L
DENON DCD-735 PCM61
DENON DCD-755AR PCM1702
DENON DCD-800 PCM54
DENON DCD-820 PCM56
DENON DCD-890 PCM61P
DENON DCD-920 PCM61
DENON DCD-980 PCM61P
DENON DCD-1015 PCM61P
DENON DCD-1100 PCM53JP-V
DENON DCD-1400 PCM56
DENON DCD-1420 PCM54HP
DENON DCD-1450AR PCM1702
DENON DCD-1460 PCM61P
DENON DCD-1500 PCM54HP-K
DENON DCD-1500mk2 PCM56P-J
DENON DCD-1520 PCM64
DENON DCD-1530 PCM61
DENON DCD-1550R PCM61
DENON DCD-1550AR PCM61P
DENON DCD-1560 PCM1701
DENON DCD-1650R PCM1702
DENON DCD-1800 PCM53
DENON DCD-2560 4x AD1862
DENON DCD-2700 4x PCM1702J
DENON DCD-S10/3000 PCM1702J
DENON DCD-3300 PCM56P-K
DENON DCD-3520 PCM64
DENON DCD-3560 PCM58P-K
DENON DCD-S1 4x PCM1702J-K
DENON DCM-280 PCM1748
DENON RCD-100 PCM1710
DENON UCD-F10 PCM61
DIORA CD-502 TDA1543
DUAL CD130 CX20017
DUAL CD20 PCM53
EXPOSURE CD TDA1545A
EZO FOG STAGE3 AD1853
FISCHER AD935 LC7881
FISCHER Z1 PCM58
GRUNDIG CD103 LC7881
GRUNDIG CD9000 TDA1541A
HARMAN KARDON HD200 YM3020
HARMAN KARDON HD500 PCM53
HARMAN KARDON HD710 MN6474
HARMAN KARDON HD720 PCM1710
HARMAN KARDON HD730 SAA7350
HARMAN KARDON HD740 PCM1702U
HARMAN KARDON HD750 PCM1732
HARMAN KARDON HD760 PCM1702
HARMAN KARDON HD7225 MN6474
HARMAN KARDON HD7300 PCM61
HARMAN KARDON HD7325 MN6474
HARMAN KARDON HD7525 PCM61P
HELIOS MODEL1S CS4328 (36 bit, ETNA)
HELIOS MODEL2S CS4328 (36 bit, ETNA)
HELIOS MODEL3S CS4328 (36 bit, ETNA)
HELIOS STARGATE CS4328 (36 bit, ETNA)
HEYBROOK SIGNATURE PCM67
HIGH TECH GOLDLINE CX904 YM3020
JOLIDA JD-100A PCM1716E
JVC XL V22 PCM54
JVC XL V221 LC7881
JVC XL V250BK PCM56
JVC XL V311BK MN6471
JVC XL V464 MN35500
JVC XL V1100 PCM54
KENWOOD DP47 TD6720N
KENWOOD DP460 TD6709N
KENWOOD DP850 CX20152
KENWOOD DP-880SG PCM56P
KENWOOD DP1080 LC78620E
KENWOOD DP1100D CX20152
KENWOOD DP1510 PCM56
KENWOOD DP2000 CX20152
KENWOOD DP2010 PCM56P
KENWOOD DP2080 LC78620E (LC78820)
KENWOOD DP3080 SM5864
KENWOOD DP4090 KAN03
KENWOOD DP5020 PCM1701P
KENWOOD DP5090 MN35502 JVC
KENWOOD DP7002 PCM1702
KENWOOD DP7020 new PCM1701P
KENWOOD DP7030 CXD2552
KENWOOD DP7060 TDA1547
KENWOOD DP7090 8x PCM1702
KOREA CHINA CD 022 KDA0316LN
KOREA HCD 630 Y3015
KRELL KAV280 PCM1704
LINN GENKI PCM1723
LUXMAN D 102 TD6709N
LUXMAN D 103 PCM1701
LUXMAN D 112 1x PCM56 (s/h)
LUXMAN D2 92 LC7881
MARANTZ CD7 TDA1541AS2 (double crown)
MARANTZ CD10 TDA1547
MARANTZ CD11LE TDA1547
MARANTZ CD11mkII TDA1547
MARANTZ CD14 TDA1547
MARANTZ CD15 TDA1547
MARANTZ CD16D TDA1547
MARANTZ CD17mkII TDA1547
MARANTZ CD17mkIII PCM1716E
MARANTZ CD19 SM5872
MARANTZ CD34 TDA1540
MARANTZ CD38 TDA1545
MARANTZ CD40 TDA1541A
MARANTZ CD42 SAA7350
MARANTZ CD43 SM5872BS
MARANTZ CD45 TDA1540
MARANTZ CD48 TDA1549
MARANTZ CD50 TDA1541
MARANTZ CD52 SAA7321GP
MARANTZ CD52SE SAA7350
MARANTZ CD53 SM5872BS
MARANTZ CD56 TDA1541
MARANTZ CD60 TDA1541A
MARANTZ CD63 SM5872BS
URL is death unfortunately.On this site the D/A converter list contains mistakes.
The original D/A Converter List has been created by me.
And I have placed it here:
404 Not Found
And I periodically update it and I correct it from mistakes.
Vasily aka VasilTech
(Belarus, Minsk)
I am looking of all CD player and d/a converter devices equipped with DAC-IC's from Analog Devices and DAC modules from Ultra Analog like those examples:
CYRUS dAD3Q AD1861
CYRUS dAD7 AD1861
MARK LEVINSON No. 390S AD1853
NAKAMICHI CD PLAYER 4 AD1864N
PHILIPS CDR-950 AD1855
TEAC VRDS 25 AD1862J
WADIA 23 AD1865
Currently URL as follow:On this site the D/A converter list contains mistakes.
404 Not Found
(Belarus, Minsk)
CD-Player-DAC-Transport List
I am looking for cd player from Philips where this MAB8441P processors in use:Hello, here is the actual link:
1) MAB 8441P T018 DSD9136 (operating MCU/user processor)
2) MAB 8441P T162 DSD8931 (radial servo processor)
According the listing under your URL I note a wide range of models from Philips, which I summarized here:
Philips model CD-:
10-50-60-80-85-85M-94M-100-101-104-110-115-130-140-150-151-152-160-162-163-164-165-200-202-204-207-210-230-300-303-304-304MKII-320-340-350-351-360-371-372-373-380-450-460-465-470-471-472-473-480-482-492-500-502-560-580-581-582-584-600-604-605-608-610-614-615-618-620-624-630-634-640-650-660-670-680-690-692-710-711-713-720-721-722-723-732-740-750-751-753-770-771-780-781-782-820-824-830-834-840-850-850MKII-880-910-911-920-921-930-931-940-950-951-960 and AK-: 601-603-630-640
I guess, that at least one of those models contain this MABs.
If I know the according model, I will download the service manual for repair a Micromega DUO transport.
Thank you for your advice.
