S/PDIF to SPORT receiver PCB - Page 4 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 5th November 2008, 05:42 PM   #31
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
Hello Ian,
I just came across this thread. Congrats on your board. I wanted to point you out on this unit if you are planning to expand, or just for the sake of idea exchange:
http://www.pilghamaudio.com/index.asp?pgid=55
I use this receiver/upsampler/clock in my Behringer DCX2496 and I am trilled with the quality.
It is interesting what you are trying to do because that as a stand alone board could have many uses. I was just researching on doing mod to take SACD digital signal out of Oppo player. It seems that the very same board that you are making if equiped with choice of S/PDIF output will do just that. I was pointed out by Rossi to this product:
http://www.twistedpearaudio.com/digital/wm8804.aspx
My understanding is that after you have done this type of board all that is needed is to add DAC to it, something like AKM4396 and voila - you have a full DAC. Based on your writing it seems like you are looking into asynchronus DA conversion, and this is what Frank's SRC board is. That is why is maybe interesting to leave possibility of connecting different DAC chips on the same board through the adapters.
So since you went to expand your board to all the regulators and TI part , you are almost there for something that could be as multipurpose unit.
I am sorry if I am simplifying things but please correct me if I am wrong. If you have an interest in going this rout please add me to the list of participants for the board!
www.burningamp.com
Old 5th November 2008, 07:15 PM   #32
Lucifix is offline Lucifix  Europe
Send a message via AIM to Lucifix Send a message via MSN to Lucifix Send a message via Yahoo to Lucifix
Lucifix,
are you able to read out all the config of the SRC4392 using SPI? I'm considering using this chip on a board which is IO limited. I'll have a full SPI available with one CSN pin and only one additional IO pin.
I see that the PLL lock is available on a pin. But I was hoping not to waste IO on it if it's available on SPI. And I don't want to add a separate MCU to monitor stuff on the board. Insted I'm planning to use the SRC4392 GPO pins to turn various stuff on and off (control I2S multiplexer since the board will also bridge to a CD drive).
  Theoretically, anything that chip can offer must be read/write through serial comm port. I didn't have any problems until now. I choose SPI from two reasons: it's faster than I2C and it uses unidirectional lines which can be easely interfaced to 5V uCs (wired through CPLD in my case). I suggest to use SPI mode (mine is software emulated, no HW peripherals)... DMA works there very good.
   The signal You're talking about is the same as "UNLOCK" bit in DIR Status Register 2 (0x14)... been there, done that. You could configure the corresponding SRC's interrupt pin or successively read the register through serial interface. Also, You'll need one LVCMOS uC to properly configure this chip at power-up. Unfortunately, there's no hardware mode here...
  Best
www.luckit.biz
"The Universe speaks in many languages but only one voice.[...]It speaks in the language of hope. It speaks in the language of trust. It speaks in the language of strength and the language of compassion. It is the language of the heart and the language of the soul. But always it is the same voice. It is the voice of our ancestors speaking through us and the voice of our inheritors waiting to be born. It is the small, still voice that says: we are one!" (G'Kar)
Old 5th November 2008, 10:12 PM   #33
borges is offline borges  Norway
Thanks! In my system I already have an MCU (atmega16) that controls the display (4-bit mode), RC5 (remote control), user interface, CD drive state machine, DSA (CD drive serial control) and uses SPI for an analog volume control, FPGA init and now the S/PDIF receiver. It's starting to get crowded in there, so that's good news.
Borge
Old 6th November 2008, 12:52 AM   #34
diyAudio Moderator Emeritus
Iain McNeill's Avatar
yes the status registers (7 of 51) give a great deal of intelligence on the audio stream. I particularly like the hi accuracy SRC input and output ratio registers that can tell you how many percent the incoming stream is off reference clock frequency.
Vladimir,
I see now I should have put a PIC option on the PCB. You are right, it would be a perfect interface block then. I might just do it anyway as there were a couple of minor errors on the board (notice the missing pins on the 90pin connector
Lucifix,
Thanks for the confirmation. I'm pretty sure I messed up my clock phase & data config somehow.
are you saying you talk to the SPI using a serial RS232 port? Can it be done?
Old 6th November 2008, 05:33 AM   #35
  Nice system you have there! What's the FPGA for?
  I've worked for few days with uC's hardware SPI (BTW I'm using a PIC18F uC) but I didn't find any option good enough to properly send/receive more than 16 bits of data in one "shot" (HW SPI CS signal was the main problem) so I've drop out the HW option and switch to the SW one.
  For DMA you should keep the CS pin low to enable auto increment mode. I suppose, the HW serials will transfer 16/32 bits at most with CS pin controlled by internal state machines. So, there's no chance to make full DMA transfer in HW... only register-by-register R/W (unless you're working in FPGAs).
  In my perspective, USART (RS-232) module is less flexible than SPI... maybe it's not an option at all as long as it have the data length of 8/9 bits. I wouldn't go that way. BTW are you using BlackFin to feed the SRC43x2 through SPI interface?
  Best
www.luckit.biz
Old 6th November 2008, 07:00 AM   #36
Sounds to me like you'll have to program an MCU in the middle. Whenever I code up pretty much anything in embedded, first thing I do is put in RS232 for debug. Ant then the last thing I do in the project is to selectively compile out the RS232.
One thing to be aware of in DMA type accesses via RS232 is that the MCU may not be able to forward data fast enough. Particularly if you're sending ASCII on the RS232. In that case you'll need a wait loop on the PC side.
Let me know if you plan to use RS232 to talk to SPI. I have some C code that works on AVR atmega16.
Borge
Old 6th November 2008, 04:52 PM   #37
In my application I'm using the Blackfin to communicate to the SRC over the SPI. The blackfin has DMA enabled SPI that can either disable CS after each byte or keep it low for the entire DMA dump. It's very flexible and I think this is my problem - I just haven't gotten the CPOL/CPHA configuration right.
I was just thinking of alternative applications for the board. A programmable, stand-alone SPDIF to I2S module would be handy.
As soon as I can clear some pay work out the way I'll take another look. A logic analyzer might help as well My trusty TEK465 ain't quite up to high speed digital debug.
Has anyone used any of these:
http://www.saleae.com/logic/
http://www.linkinstruments.com/mso19.htm
Old 8th November 2008, 05:51 AM   #38
Well in the end I just slowed the baud rate down to 8KB/s and sampled the clock and data on my soundcard. Worked real nice and I saw that the SPI was working perfectly.
Turns out the CPM pin must be pulled low for SPI, not high.
DOH!!
sings like a birdie now
lets see what she can do
Old 15th November 2008, 04:13 AM   #39
Well I'm impressed with my preliminary listening. I think I can hear an improvement. There seems to be more punch to the low end and overall more engaging sound - makes me want to put another track on.
Before I was listening to double converted audio - CD's played back by various means then re-digitized by my AD1836. Now, I'm digital all the way to crossover output. It's reassuring that I can hear one less conversion artifacts.
Took a while to get the SRC dialled in. I really wish the chip manufacturers gave you an interactive tool to config the registers. I had to roll my own:
SRC4392 configurator
Time to run some diagnostics
Twisted Pear - S/PDIF 4:1 MUX/Receiver Module (new, unused) n_maher Swap Meet 3 19th February 2009 05:57 PM
S/PDIF receiver recomendation borges Digital Line Level 9 14th October 2008 07:54 PM
DIR9001 S/PDIF receiver chips for sale Lord Winter Swap Meet 2 12th March 2007 02:25 PM
S/PDIF Optical to S/PDIF RCA Replacement PrecisionAudio Digital Source 2 11th February 2007 10:35 PM
Copyright 1999-2017 diyAudio
